It is currently Mon May 19, 2025 11:10 pm
PostPosted: Mon Apr 28, 2008 8:17 pm
Can anyone offer any advice on removing the stock tank out of a fl350? I have completely disconnected the tank, but can not get it out. I assume it must come out through the bottom of the frame as that is the only place that comes close to being wide enough.
PostPosted: Mon Apr 28, 2008 8:25 pm
Yep down and out its also easier if you have the cap off of it. It comes out but its a little bit of a pain
PostPosted: Mon Apr 28, 2008 8:42 pm
hmm I thought I was missing something. I will have to go and pull on it some more.
PostPosted: Mon Apr 28, 2008 11:39 pm
don't go into it thinking it will just drop out.
you have to wiggle it and tilt it around. but it comes out.
just work at it for a while, you will get it.
PostPosted: Mon Apr 28, 2008 11:57 pm
Yeah I got it, just a tight squeeze is all. I was worried I was going to break something on the first attempt I guess.
Thanks guys.
PostPosted: Tue Apr 29, 2008 12:32 am
the cap is the trick!!!
