It is currently Mon May 19, 2025 8:22 pm
Post new topic Reply to topic  [ 74 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Dec 10, 2008 11:08 pm
my fl250 was sitting for about 4 month.
I took it out Thanksgiving weekend near Yuma Arizona.
My wife and the kids road for about 5 hours thru out the weekend.
At the end of the day it turned off i din't worry becuse the weekend was over.
at home i thougth it would be a maintence issue.(carb,filter or plug)
After checking all that with no luck. I did a comp check, 30psi scary.
pictures and more info coming up
PostPosted: Wed Dec 10, 2008 11:48 pm
I hope you haven't eaten another piston.
Your pipe mods may have made it a bit leaner, though I hope not.
PostPosted: Wed Dec 10, 2008 11:54 pm
this piston only has about 15 hours on it.
PostPosted: Wed Dec 10, 2008 11:56 pm
Is it JPG or a PDF?
It appears to be undecided......
And, now it's gone.....
PostPosted: Thu Dec 11, 2008 12:00 am
sorry still learning more coming
PostPosted: Thu Dec 11, 2008 12:01 am
are those metal shavings?
PostPosted: Thu Dec 11, 2008 12:02 am
Ouch!
That's bad, is that dirt in the bottom end?
PostPosted: Thu Dec 11, 2008 12:05 am
their was a vacum leak for for about 1/2 hour thru the fuel pump port
PostPosted: Thu Dec 11, 2008 12:09 am
Wow!
With that much metal floating about in there I'd say it's probably time to do the bottom end, bearings and seals. Hopefully the rod bearing is still good.
If you're going to leave it as gravity feed you might want to braze that tube over.
PostPosted: Thu Dec 11, 2008 12:10 am
their is no debri in the crank case but i havent check with a light
PostPosted: Thu Dec 11, 2008 12:16 am
so you think the vacum leak was the problem. My Fault I should had been more careful.
PostPosted: Thu Dec 11, 2008 12:17 am
Definitely.
Sucking air will make it leaner big time.
I'm amazed it lasted 1/2 an hour that way.
PostPosted: Thu Dec 11, 2008 12:20 am
you think the rings are still good they don't look broken.
PostPosted: Thu Dec 11, 2008 12:21 am
Man too bad hope you have some bores left on your cylinder.
PostPosted: Thu Dec 11, 2008 12:23 am
It was probably running really good towards the end, but making a lot of noise, pinging, etc.
PostPosted: Thu Dec 11, 2008 12:25 am
I think i should have bore left.their is no visible damage and i think its never been bored.
I can't tell anything from the pics, looks like they're not even there to me.
PostPosted: Thu Dec 11, 2008 12:29 am
It actually ran for about 2 hour after i plugged the leak. but the damage was probaly aready done.
PostPosted: Thu Dec 11, 2008 12:43 am
Isnt it funny how well a ruined piston will run sometimes. Like my Dad has said" ran great right before it blew up".
PostPosted: Thu Dec 11, 2008 12:59 am
Ok now that we know what i did wrong:(
what can i do right. :) or can i do anything right :|
PostPosted: Thu Dec 11, 2008 1:09 am
Hee Hee
I'd be nervous about the bearings and seals, especially with that much metal being ingested, but if you clean it thoroughly and reassemble and it passed a leak down test you should be good to go.
I will look tomorrow for another STD piston, but I'm pretty sure you got the last one I had. I'm more likely to have STD rings than a piston since I've liquidated most of them this last year, but I'll look anyway.
I also have a half dozen or so engines in various states of assembly, so I'll dig into those as well.
PostPosted: Fri Dec 12, 2008 12:39 am
whats a leak down test? Any help you give me i really will appreciate Thank you.
PostPosted: Fri Dec 12, 2008 3:06 am
check this out.
http://pilotodyssey.com/rebuild1.htm
PostPosted: Fri Dec 12, 2008 9:52 pm
From the looks of that piston rings are toast. Even if they wernt after new bore or hone new rings would be recomended, sorry. Hope you cranks ok. Check it over closely.
PostPosted: Sun Dec 14, 2008 12:59 am
Im looking at a piston for sale on evil bay for 30$ the size is described as standard. does anybody know what diameter is that.
