Hi and welcome to the site.
What is the reduction ratio of the FNR box you used off the sled?
What is the reduction from the output of the sled box to the rear axle?
Going to install an air box? Ask OdyPilot on minibuggy site if he thinks you need one..
How about some specs on your buggy, length width height, suspension travel, weight etc.
Any idea on the HP ? Assuming its 70-90 hp in the sled?
Hi hoser,
Reduction of the sled FNR box is currently 39/21 = 1.86:1. I bought a 16 tooth sprocket for it, but need to get a shorter chain to use it.
The chain box to the rear axle is currently 40/12 = 3.33:1. I initially planned on a 10 tooth drive, but was worried about such a small diameter sprocket holding up.
The current overall gear ratio is 6.2:1. This is a little higher than I wanted as I was planning on around 8:1, but there is certainly no shortage of torque right now.
I may do an air box eventually. Depends if I end up riding in the mud/water or only take it out in drier conditions. I agree it's a good idea to have one, but it's not as high on the priority list as other items right now.
I believe the horsepower is around 70-75. The Engine, CVT, and FNR chaincase is from a '94 Polaris Indy 440. The air intake and Aaen exhaust probably allow it to make a bit more power than stock, but I have no way of knowing how much.
Specs are:
Overall width: 62"
Overall length: 92"
Overall height: 58"
Wheelbase: 65.5"
Front wheel travel: 12"
Rear wheel travel: 13"
Weight: haven't measured it yet, but estimating under/around 550lbs
4 gallon gas tank
Four wheel disc brakes, dual master cylinders
Rack and pinion steering, 1.5 turns lock to lock
Fox 2.0 air shocks all around, 8.5" stroke front, 10" stroke rear
Rear hubs, brakes, bearings, CV joints from Polaris Sportsman ATV
Front hubs, bearings, brake rotors from Polaris Predator ATV
All other suspension components and frame custom built
