It is currently Sat May 17, 2025 8:22 pm
PostPosted: Thu May 07, 2009 9:55 pm
Started on hares spare basket case Pilot Engine, it came in a bazillion pieces.
The case have had a weld repair on the clutch side by the crank, nice looking repair job.
The crank is nice and tight but it came with a bearing fused to the clutch side I had to grind it off to remove.
PostPosted: Thu May 07, 2009 9:57 pm
Looks like this Engine had seen a rod failure in the past you can see where the rod hit the cases, I hoserized the cases for better oiling and lapped them they are nice and flat.
File comment: Weld repair
PostPosted: Thu May 07, 2009 9:58 pm
Crank installed in cases with new Honda bearings.
PostPosted: Thu May 07, 2009 10:04 pm
Before I can assemble any further I need a balancer if you remember I use the balancer out of this Engine for the K&N Filter HAIRY-ASS-Pilot CSI project. someone had modified that one and remove the balance weight
I need to go through the rest of the pile of parts to see if their is anything else I need I am sure their are some nuts and bolts missing somewhere lol
The right side case needs a few hours of cleaning up and rebuilding the water pump before its ready to install, all the rest of the parts are plenty dirty too. :-)
Registered users: Bing [Bot], c5racer, eseymour72, Google [Bot], liduno, MSN [Bot], Q
