It is currently Wed May 14, 2025 11:24 pm
Post new topic Reply to topic  [ 247 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
 Post subject: My Sons FL350R Restore
PostPosted: Sun Jun 21, 2009 2:44 am
Hello to one and all, I bought this 1985 Odyssey FL350R last year off of ebay for my son.
I am an auto tech. by trade and tell my customer's all the time to look under the hood before you buy anything, well I did not look under the hood and got took real good. It was the flashy red paint that did it!!!
Anyway I took the Odyssey apart just to replace the steering parts, brakes, u-joints and wheel bearings. I was going to have it done for him for christmas.
Well that did not work out to well, I have since taken it completely apart and started restoring it from the ground up.
His birthday is this Thursday the 25th., I have closed my shop for the week and am trying to finish it for him.
I have set things up so that I have until Sunday the 28th.
Wish me luck I am not as young as I used to be and more of a perfectionist than ever ( drives me crazy ).
File comment: Freshly powder coated red and clear
File comment: I spent an entire day last weekend wire brushing the transmission by hand. Tried cleaner's, wire brush on drill and sand blasting. All did not work, the drill and sand blasting was leaving deep grooving.
File comment: In the end a small wire brush the size of a tooth brush and a lot of elbow grease did the trick.
File comment: Gas tank is double lined, brand new gas cap (lock set), three coats of black and three coats of clear, original decals, new honda wheel bearings and seals in the axle carrier.
File comment: Brand new honda axle.
 Post subject: More pics
PostPosted: Sun Jun 21, 2009 3:04 am
More pics.
File comment: Total rebuild on pilot caliper for the odyssey. Done today.
Caliper done getting ready to install e. brake bracket.
If you look at the bracket you can see what the caliper looked like before brushing. All honda parts.
File comment: Caliper and rotor installed.
File comment: Comet driven clutch and pilot e. brake cable installed.
 Post subject: More pics.
PostPosted: Sun Jun 21, 2009 3:10 am
Last two for now.
PostPosted: Sun Jun 21, 2009 12:39 pm
wow,excellent job,hope your son appreciates you closing your shop for a week to finish it.Will you adopt me? lol
 Post subject: fl350 restore
PostPosted: Tue Jun 23, 2009 10:16 am
Thank you, it is going very slow we have been sanding and painting for two days.
My son does not have a clue what my wife and I are going thru for him, he thinks we work all the time because we want to.
I will post some more pics soon.
PostPosted: Tue Jun 23, 2009 3:26 pm
Nice job! Keep up the good work.
How old is your son? What a great present
PostPosted: Tue Jun 23, 2009 4:05 pm
really nice... I didn't realize that the pilot caliper would work on a 350
PostPosted: Tue Jun 23, 2009 6:33 pm
nice that you added a fuel sensor. Looks really good
PostPosted: Tue Jun 23, 2009 11:16 pm
Hello, my son is going to be 16.
The pilot caliper bolts right on, the only difference between the two is the e. brake bracket and the mounting bracket.
I had to use a pilot brake cable, the whole on the e. brake arm at the caliper where the cable hooks up is smaller on the odyssey.
The pilot brake cable is 5 or 6 inches longer which is a bummer but I think it will work out ok.
The advantage is you have the brake indicator, the return spring and you can hook a brake switch to it. Which I am doing at some point.
I am putting a pilot steering wheel on, I first did this to get rid of the cables and go to all hydraulic.
I decided to use a pilot wiring harness and add all the switches and sensors, hope it goes well not even close to that stage yet.
I painted again all day today, I have almost everything painted.
I will put the front suspension and hopefully the motor (( Internal Combustion Engine ? )) in tomorrow.
I will post some more pics when I have some actual progress and more parts put on. Hopefully tomorrow.
PostPosted: Fri Jul 03, 2009 7:40 pm
Steve -hate to mention this but that tank will need to be removed to install the motor (( Internal Combustion Engine ? )) to trans brackets,you'll never get the bolts in them at all.Love the fuel sensor and Pilot harness, please keep us up on the install and useage of them, are you going to use a Pilot wheel with it, I do think the splines are the same on the top of the steering shafts,meaning the 350 can be used on the Pilot wheel.Are you going to fab brackets for the Pilot electrical systems (which mount on the frame)or eliminate them?
The tank will slide back in there after you tighten and install the brackets and trans-no worries at all there.
PostPosted: Fri Jul 03, 2009 10:37 pm
Hello Gregg, yes I know. I am going to turn the bracket by the fuel tank around backwards, I have checked and it will clear with no problems and in the future I might not have to remove the tank to pull the motor (( Internal Combustion Engine ? )) or trans.
Yes I am using a pilot wheel and brackets for the wiring, I have a bent pilot frame that I am going to cut the brake switch bracket off of and I have a pilot radiator assy., I am going to cut the whole cross bar out of the frame where the radiator mounts to from the pilot frame. Not sure how that is going to go yet.
I will post some more pics here in just a bit.
Have a great night.......
 Post subject: FL350 Restore
PostPosted: Fri Jul 03, 2009 11:24 pm
Ok my deadline is shot to hell, I should have known better.
I have not been able to do hardly anything this week, had a lot of work after being closed.
Everything is going well, spent a good amount of the time I had off just sanding, wire brushing and painting painting painting.
Here are some pics of where I am at now, getting back on it tomorrow.
File comment: My Hillside Honda head.
Thank you Thank you, Mudbogger.
File comment: Front end together with new Speedchaser bushings and shims.
Awesome stuff Speed, thank you.
PostPosted: Fri Jul 03, 2009 11:32 pm
More pics.
File comment: My wife worked her butt off cleaning this motor (( Internal Combustion Engine ? )) with a wire brush and a tooth brush.
File comment: New front bumper.
I had it powder coated with the frame.
PostPosted: Fri Jul 03, 2009 11:35 pm
More.
PostPosted: Fri Jul 03, 2009 11:37 pm
VERY VERY NICE ---clean-crisp-I love it-keep it up!!!!
I especially love the OEM bolts and how the heck did you find OEM rubbers for that front bumper?They are very very hard to find-nice touch indeed!!!!
Are those rubber dust seals on the front end new, they look it!!!
PostPosted: Fri Jul 03, 2009 11:38 pm
Last set for now, I will post some more soon.
PostPosted: Sat Jul 04, 2009 12:06 am
Good evening, are you talking about the seals for the J arm bushings. If so no they are not new I wish, I have been scrubbing everything with brake cleaner and soap and water. Lots and lots of elbow grease.
I got very lucky and was able to get a brand new front bumper kit off of ebay.
Thank you, I told you I was a perfectionist almost to the point of insanity. Actually I am driving my self crazy wanting everything just right.
For example I painted the front brake backing plates and then sanded the contact area where you mount them, I put a little silicone on the mounting surface and lock tight on the bolts and installed one of the backing plates. I then realized that some of the surface I had sanded was overhanging the mounting surface, thought about just touching it up but I could not get to the whole area. So I paced the floor for about five minutes and then decided to take the dam thing off and paint the exposed surface area. I had to clean all the silicone back off and clean the bolts again, see what I mean.
One thing that amazed me is that the ball joints are in excellent condition, no play very tight. Did Honda make good stuff or what.
Anyway I better get some sleep, have a great 4th. of July Gregg and everyone.
Take care and be safe.
PostPosted: Sat Jul 04, 2009 1:29 pm
SC, you're doing a fantastic job, I wish I had the same anally retentive pedantic nature.
I just do what I can to make mine work & then I'm happy. :-)
Keep up the good work & post em as you get em. Pics that is.
PostPosted: Sun Jul 12, 2009 9:55 am
The front suspension and brakes are all together, I am putting the steering parts and column in today.
PostPosted: Sun Jul 12, 2009 10:01 am
More pics.
PostPosted: Sun Jul 12, 2009 10:02 am
Three more.
PostPosted: Sun Jul 12, 2009 10:17 am
excellent job Steve-KEEP IT UP!!
PostPosted: Sun Jul 12, 2009 10:57 am
Nice. Real nice.
PostPosted: Sun Jul 12, 2009 4:42 pm
Wow looks really good. It will be very sharp once its done.
PostPosted: Mon Jul 13, 2009 12:20 am
Thanks guy's I really appreciate it, now I need a pilot steering wheel cover with all the switches.
I bought one a while back but the switches are all melted, if anyone has the cover and switches or even the whole steering wheel assy. please let me know.
Thank you.
Registered users: Baidu [Spider], Bing [Bot], Google [Bot], John l, Lanix, Q, Rppjr, stix
