It is currently Sun Apr 28, 2024 9:41 pm
Post new topic Reply to topic  [ 214 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Thu Dec 10, 2009 1:21 pm
Turbotexas wrote:
ok I found a place that has the nitrogene... $20 a pop sooo... It is the motorcycle shop and he works on atv's too, but I don't know if he will know what I need??? and quite honestly I don't either LOL
I will check sag first, I am aiming for 25% to 30% is this right?
Now I feel it is bottoming out too easy... adding nitrogen will increase ride hieght, but also reduce sag am I correct?
Right adding nitrogen will increase ride height and reduce sag, it will also make the shock rebound faster, adding more oil will increase the compression ratio meaning as the shock reaches the end of travel it will get harder or stiffer keep you from bottoming out.
I send an email to Downsouth motorsports, and he seems to think the valving is wrong. He didn't know what kind of vehicle these were going on either so just went off of what I told him online order form. He said these shocks are more for slow speed stuff and then I reminded him of the redline revolt! I am going to take them off and send to him to revalve... If anyone knows how the redlines are valved let me know so he has something to work with besides my video... The rubber donut is not a stopper, it is used to see how much shaft is being used, so I will go out and fim some more!!!
On a good notew the hood I made sure blocks the cold wind down and makes driving warmer!!!
PostPosted: Thu Dec 10, 2009 1:39 pm
lutrev wrote:
You can throw your old shocks on and TURBOVISION the same sequence of driving, and see what you have. Would be interesting. Maybe E-mail redline, or phone them for their valving?
Yea I am going to... since I have to put the shocks back on anyway...
PostPosted: Thu Dec 10, 2009 3:06 pm
Read all this ?
http://www.pirate4x4.com/tech/billavist ... index.html
PostPosted: Thu Dec 10, 2009 3:37 pm
Read all this ?
parts of it... will later tonight after it gets dark...
PostPosted: Thu Dec 10, 2009 4:11 pm
here is todays first installment!
http://www.youtube.com/watch?v=RQJvaNQd7JQ
PostPosted: Thu Dec 10, 2009 4:36 pm
from our PM's the Revolt shocks mount different than the Pilot thus having a different motion ratio and are longer so the setup would be different.
Unfortunately you are the ginny pig, looks to me like your shocks are set up perfect for the top 3/4 of the stroke but the bottom 1/4 is to soft can they make the bottom 2" stiffer? also looks like you need less rebound.
PostPosted: Thu Dec 10, 2009 5:00 pm
here is dash cam...
http://www.youtube.com/watch?v=pbLd6HYU2TE
PostPosted: Thu Dec 10, 2009 5:02 pm
I am wondering if the nitrogen would do the last 2 inches...
PostPosted: Thu Dec 10, 2009 5:23 pm
What I see is your bucking just like the stock shocks. Looks like to me that your rebound is way to high and your compression might be a bit high also. What is your valving numbers and your psi set at?My valving is 50/70 and i have no bucking at all My psi is set at 200 but I weight 250 . You might want to call fox and talk to a tech and explain that the rear end is bucking and see what they recomend.
PostPosted: Thu Dec 10, 2009 5:58 pm
Read all this
http://www.pirate4x4.com/tech/.....index.html
PostPosted: Thu Dec 10, 2009 6:09 pm
Read all this
yes Master I will... after its dark outside LOL
I am busy riding and videoing!!!
What a way to spend MY Birthday!!! LOL
PostPosted: Thu Dec 10, 2009 6:26 pm
here is last one...
http://www.youtube.com/watch?v=Wl9SlV1yr0E
only cause it is getting cloudy and colder LOL
PostPosted: Thu Dec 10, 2009 6:58 pm
lutrev wrote:
Awesome video, but I have a hard time believing they valved yours the same as mine,or the pressure? I never experienced the bottoming, or bucking. With me being lighter, wouldn't mine be even worse? And I have no idea why, but they did seem to ride better each time the first few trips.
I would think its the other way... me being 20 pounds heavier makes it bottom that much easier, and bounce that much moer... I didn't think 20 # would matter???
PostPosted: Thu Dec 10, 2009 9:23 pm
I braved the cold for one more! I figured out the slow motion too...
http://www.youtube.com/watch?v=SHwG1rD9XPg
PostPosted: Thu Dec 10, 2009 9:24 pm
According to these guys they don't like the fox's air on there revolts..
http://www.redlineutvforums.net/suspens ... -elka.html
I wonder if I should have got rezzies???
PostPosted: Thu Dec 10, 2009 10:20 pm
Once on Ol Blue I got to Little Sahara and found that I had one shock that had lost it's pressure and was flat, fortunately, Hoser was there and had a kit to refill it and saved my trip. After that I had a kit made up to refill them. Basically, it is a small nitrogen bottle, hoses and gauges to control the amount added or bled off. I think it cost me around 200 bucks, and since it made it easy to change the settings for various riding conditions I considered it good investment, Now on the Tiger, I have coil overs with rezzies and haven't used it since.
I would think if you are handy enough that you might be able to make up a kit yourself for a bit less, someone here may know what all you would need to do it.
PostPosted: Thu Dec 10, 2009 10:38 pm
lutrev wrote:
I read a few posts, these guys buy Elkas like I buy underwear, way to rich for my blood.16 grand for machine,then 5500 for shocks?
LOL I thought the same LOL only thing I worry about now is the fade they are talking about... I never thought of that LOL
PostPosted: Thu Dec 10, 2009 10:49 pm
you worry too much :-)
PostPosted: Thu Dec 10, 2009 11:11 pm
lutrev wrote:
For 20 dollars a pop, they should supply a "happy ending" as the volume in the shocks would cost them a penny. high pressure, but very little volume. They should charge 20 for making it available forever, and I would not want a happy ending from any of the mechanics up here :shock:
You are funny read to much craigslist LOL
i was told to drop the nit to 125 and to see what that does, then to send them back for re-valving...
PostPosted: Thu Dec 10, 2009 11:13 pm
I like the stock set-up at 60/90 with 200 psi, try that mabye if your sending them back?
PostPosted: Thu Dec 10, 2009 11:16 pm
where is the "stock setup" setting coming from??? stock what...
200 psi seems like it would jack your ride hieght way up... do you remember how much oil you had???
PostPosted: Thu Dec 10, 2009 11:21 pm
Lutrev you asked about the camera, just saw an add on tv radio shack has them for 99.00 it is the nikon coolpix L20
big fat black man singing OH SNAP LOOK AT WHAT I SAW...
PostPosted: Fri Dec 11, 2009 12:15 am
lutrev wrote:
well im a skinny white guy that cant sing, but I need a decent camera, took some vid with my blackberry,and got some good video but could not upload onto the site. Ill grab one in the new year as I wont be able to ride till march or april, we just got 2 feet of snow so Ill be riding my john deere pushin snow. Thanks for the info.
LOL You don't have a mini sd card in your blackberry? try emailing it to yourself???
PostPosted: Fri Dec 11, 2009 3:29 pm
Why are you worried so much about ride height? Worry about the ride and feel and dial that in. Get your valving and pressure set to a good feel and balanced for your racing and when you ride and your ride height will be fine.
PostPosted: Fri Dec 11, 2009 3:32 pm
I think hes refering to using the fox airs on your stock suspension. Meaning its not aftermarket suspension
Registered users: Bing [Bot], Duneit, Google [Bot], liduno
