It is currently Mon May 19, 2025 2:41 pm
Post new topic Reply to topic  [ 277 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12  Next
PostPosted: Thu Feb 11, 2010 12:01 pm
thank you hoser.
PostPosted: Wed Feb 24, 2010 2:21 pm
Hey Jim, what are you going to be using for an overflow bottle? I wound up using a bottle from a banshee and made an custom bracket to hang it from the top of the cage in the triangle area where everyone likes to put number plates. If I roll it the bottle's bracket should bend and not do damage to the bottle (I hope).
PostPosted: Wed Feb 24, 2010 4:16 pm
really havent put to much thought to it yet.bin checken out ebay from time to time hopin to find something nice and small that i can tuck away somewhere.hopefully in the next week or two i can get out to the garage and get some real work done.its just bin to dam cold here to work out in the garage with no heat.hopefully trevor has the heads soon so i can button this thing up and pressure test.still waiten for the pipe this is going on 6 months :shock:
PostPosted: Wed Feb 24, 2010 6:53 pm
Damn! I thought 4 months for the head was a long time! Hopefully we will get something soon! I don't know about you but I'm starting to get impatient!
You know, once that thing is all buttoned up we will be requiring pictures from every possible angle (close ups) of that bad boy!
PostPosted: Wed Feb 24, 2010 10:01 pm
very nice looks great ...
PostPosted: Thu Feb 25, 2010 7:29 am
thank you sunblock.rand im like a little kid everyday when i come home hoping for a nice big box sitting on the steps of the house.hopefully they will ship soon.
PostPosted: Thu Mar 04, 2010 6:22 pm
one step foward two back.after asking alot of questions and reading i took my cylinder back off the Engine and shipped it to trevor at hillside honda to cut the deck of my cylinder to correct the squish to the proper clearence.then when he makes my hillside head he will change the cc's in the dome to correct the compresson to run on pump gas.so now it back to wait time.hopefully i can get this Engine back together before the end of the month.the weather is startin to warm up gettin the itch to go ride.
PostPosted: Thu Mar 11, 2010 4:57 pm
Hey Jim, are you going to plug the holes in your radiator where the thermo switches are? If you didn't have them welded over and are looking for a plug to fit in them the threads are a M18 x 1.5. I used an Oil pan drain plug Dorman # 090-114.
PostPosted: Thu Mar 11, 2010 5:27 pm
havent really gave it any thought yet.that's on the small details list LOL that i hope i get to someday.
PostPosted: Thu Mar 11, 2010 7:17 pm
Jim327, did you tell him how much to take off. Is the dome cc the only change to the head he is gona make. Just curious.
PostPosted: Thu Mar 11, 2010 8:11 pm
trevors going to set my squish at .035 to .040 and is going to correct the compression (cc the head) to run on pump gas.as soon as he shoots me over the numbers i let you know.
PostPosted: Sun Mar 21, 2010 7:06 pm
ok spent the day working on the oddy.ran all the wires for the switches,installed front works shocks,flushed and serviced the brake system.
PostPosted: Sun Mar 21, 2010 7:09 pm
pics
PostPosted: Sun Mar 21, 2010 9:28 pm
What are the two switches on the aluminum panel for?
PostPosted: Sun Mar 21, 2010 10:14 pm
that's the mounting plate for my digitron
PostPosted: Sun Mar 21, 2010 10:23 pm
Now that I downloaded it and zoomed it, I can see what it is. For a minute there I thought you had two more switches.
PostPosted: Sun Apr 18, 2010 1:36 pm
ok played around a little bit today mounted up a new gs series autometer gauge and 2 30 amp relays for the pump and fan.Rand thanks for the info for the sensor plug fitting it worked out great.
PostPosted: Sun Apr 18, 2010 4:57 pm
You're welcome!
PostPosted: Thu Apr 29, 2010 11:04 am
I was up 'till about 3 reading this post from front to back...Really like the determination you guys have! I've noticed a lot of you that have 6 month+ projects going because you want to get it done right. I know ya'll have more patience than me....I hate being out a weekend!!
I really like the 450R radiator setup with the tubing...mounting looks good...and the water pump setup is nice. Can't wait for you to get you head and pipe in so we can see this thing move!
-JP
PostPosted: Thu Apr 29, 2010 2:33 pm
thank you JP.got my fingers crossed hopefully by the end of may :shock: jim
PostPosted: Thu Jun 03, 2010 9:17 pm
good day today got my cylinder and head from Trevor.the head turned out great two thumbs up trevor.anyway heres my numbers .035 removed from cylinder.my squish is now .041 and compression hit 178 psi.heres a couple pics
PostPosted: Thu Jun 03, 2010 9:25 pm
Looks great!
PostPosted: Thu Jun 03, 2010 9:50 pm
That looks like a piece of art!
PostPosted: Thu Jun 03, 2010 10:05 pm
thank you
PostPosted: Fri Jun 04, 2010 10:52 am
Man now that's sweet. He did say pump gas right. Lucky guy.
