It is currently Sat May 10, 2025 3:19 pm
Post new topic Reply to topic  [ 247 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10  Next
 Post subject: FL350R Restore
PostPosted: Sat Jun 05, 2010 10:07 am
Two more.
SNC10111.JPG [31.34 KiB]
Downloaded 306 times
SNC10112.JPG [32.23 KiB]
PostPosted: Sat Jun 05, 2010 10:19 am
wow,really nice work.love the attention to the small details jim.
PostPosted: Sat Jun 05, 2010 5:45 pm
Looks great Steve, really does! Can you take a quick picture of the mounts used for the Pilot headlights please.I need to copy them for my KAWONDA project.
PostPosted: Sat Jun 05, 2010 8:55 pm
Hello Gregg, I used the stock FL350 headlight brackets. They worked out great, I did have to wrap some tape around the original rubber to tighten the brackets up enough so they do not move.
Thank you Gregg and Jim for your kind remarks.
Have a great night.
PostPosted: Sun Jun 06, 2010 8:29 am
OH NO KIDDING! Thanks much Steve!
PostPosted: Sun Jun 27, 2010 9:07 am
Hello to all, well first off SHE RUNS. Fired her off yesterday, idles perfect with no adjustments so far. I have only done two heat cycles, had a heck of a time reworking the exhaust then I get it on and fire her off and the darn silencer is leaking like a siv out of its housing. I had to take the silencer back off and cut the rivets to pull out the end and reseal, I used copper high heat silicone to seal the end that should have been sealed from the factory. It is a big gun silencer by the way, brand new. I hope it holds, I am letting it set 24 hrs.
The wiring worked out perfect, everything works the only thing I did not hook up is a reverse light. The wires are there if I want to add one later.
Here are some pics, I will get some more as I get the other things put on. It should go much faster now, I am starting on the crank case breather this morning and hope to have the seat in by tonight.
Have a great day.
SNC10011.JPG [38.62 KiB]
Downloaded 189 times
SNC10012.JPG [37.31 KiB]
SNC10013.JPG [37.63 KiB]
SNC10015.JPG [28.37 KiB]
SNC10016a.JPG [34.02 KiB]
PostPosted: Sun Jun 27, 2010 9:09 am
More pics.
SNC10022a.JPG [43.38 KiB]
Downloaded 188 times
SNC10122.JPG [34.63 KiB]
SNC10128.JPG [20.64 KiB]
SNC10148.JPG [41.19 KiB]
PostPosted: Sun Jun 27, 2010 9:10 am
More.
SNC10158.JPG [45.15 KiB]
Downloaded 187 times
SNC10160.JPG [41.42 KiB]
PostPosted: Sun Jun 27, 2010 9:12 am
More.
SNC10162.JPG [37.8 KiB]
Downloaded 185 times
SNC10163.JPG [43.69 KiB]
SNC10164.JPG [50.71 KiB]
SNC10165.JPG [48.75 KiB]
PostPosted: Sun Jun 27, 2010 9:14 am
Last one for now.
PostPosted: Mon Jun 28, 2010 11:11 pm
The first pic. is of some new oem air dams and new oem headlight buckets, I got them put on today.
I also finished the crankcase breather and installed the seat today.
I used a brass transmission cooler line adaptor fitting for the crankcase breather, I cut it down and cut new threads 14mm x 2.0. I then took a 1/4 brass nipple and screwed it in to the fitting and saudered it.
The breather hose is inside some spark plug wire heat shield.
SNC10001a.JPG [22.1 KiB]
Downloaded 159 times
SNC10004a.JPG [35.03 KiB]
SNC10008a.JPG [34.32 KiB]
 Post subject: FL350R pilot seat
PostPosted: Mon Jun 28, 2010 11:16 pm
One more pic. with the pilot seat installed, I bought an air suspension seat from Randy for my wifes pilot and was going to put it in the odyssey for my son but after setting it in there it looked like it would be another big under taking to get it put in so I went with a pilot seat for him. I may in the future get him a better seat.
Does any know what suspension seat will go in the odyssey, will a beard seat fit?
PostPosted: Sun Jul 11, 2010 2:05 pm
Hello to all, other than the decals, re-torquing all bolts, touch up on the paint and putting the digitron gauges on she is done. I finished her on the morning of the 4th. but have not had time to post some pictures.
I am going to break her in and astablish a wet line in the exhaust before adding the digitron gauges.
I took her out for her first ride yesterday, wanted to get on her bad but held my thumb at bay. By the end of the day I was doing half throttle short bursts man does she run and ride great. I started with a 185 main jet it may be to big but I wanted to be sure and start out fat, I will be taking her out next weekend to finish the break in and see how she does so far no problems. Everthing works perfect even the fuel level sensor.
I am using the Honda GN2 non synthetic mix oil for the break in, after break in I will be running Honda HP2 full sythetic mix oil.
I can not wait to open her up.
Take care.
File comment: New OEM mirrors and roll bar pads. Yes that is a new center bar pad.
SNC10001.JPG [30.26 KiB]
Downloaded 103 times
File comment: All new OEM fenders and fender collar washer's.
SNC10005.JPG [22.11 KiB]
SNC10012.JPG [41.01 KiB]
PostPosted: Sun Jul 11, 2010 2:50 pm
Here are some more pics they are not that great the lighting is bad. She looks so awesome in person, I wish I could just park her to look at.
I want to thank a few people, with out there help I could not have done this project for my son.
My Wife, Mudbogger, Socalgi, Hoser, Randy Bridgewater ( Odyssey Salvage ), Speedchaser, Mark ( Service Honda ), Jesse D., Pilotpete, GAPilot, Stix9567, Derek T., Jim-Don-George (A Radiator shop), Chris (southwest powder coater's), Jeff ( Honda of ), Kingjason, Chris ( Decals), Eric ( Jentsch Racing ), John ( Stainless bolt set ), Napa autoparts, and yes Ebay.
I want to give special thanks to My Wife, Gregg, Nick and Randy. You guys really went the extra mile for me and I will not forget it. THANK YOU!!!!!!!
If I left anyone out I apologize, I am getting old and my memory is not what it used to be.
When I get her totally complete with decals and gauges on I will post some pictures. Probably this winter.
Thank you all for everything and take care.......Steve
SNC10013.JPG [44.2 KiB]
Downloaded 99 times
SNC10015.JPG [46.17 KiB]
Downloaded 99 times
SNC10016.JPG [41.49 KiB]
Downloaded 99 times
PostPosted: Sun Jul 11, 2010 9:50 pm
JOB WELL DONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
 Post subject: FL350R Done
PostPosted: Sun Jul 11, 2010 10:01 pm
Hello GA and thank you.
PostPosted: Sun Jul 11, 2010 10:15 pm
you are more than welcomed..very glad to have been able to contribute to such a magnificent undertaking..even if it was in a very tiny way..again "CONGRATULATIONS"
PostPosted: Mon Jul 12, 2010 7:31 am
Very nice. Good thread!
 Post subject: Re: FL350R pilot seat
PostPosted: Tue Jul 13, 2010 6:42 pm
Randys "better" seat will bolt right in. The only problem is theres no bottom skid plate. I had one made up at a metal fabrication shop. It doubles as the heat shield. Hope this helps and your PilOdyssey really looks great!
PostPosted: Tue Jul 13, 2010 11:26 pm
Stix you need to find some good closed cell foam padding to put between your keister and that skid... My skid drops lower than youts does and I have bottomed my tailbone once on mine... The extra padding will prevent that!
PostPosted: Wed Jul 14, 2010 10:55 am
I like the stock seat. Nothing looks better IMO.
 Post subject: fl350r restore
PostPosted: Wed Jul 14, 2010 3:37 pm
Hello Stix, thank you for the pics. That is the exact seat that I bought from Randy, I sat the seat in there and decided it was to much more work at the time. I will check it out later when I hook up my gauges.
Thank you guys and take care.
PostPosted: Wed Jul 14, 2010 6:59 pm
"closed cell" foam padding, meaning it wont soak up water?? Where would I find that? I need to get some as I can feel the skid plate if I push down on the seat hard enough. THanks bud!
PostPosted: Wed Jul 14, 2010 11:28 pm
closed cell is more termed at impact dissapation not really water proof! When I was younger I used to make one of the first bull riding vest in the country i had a source here in San Antonio, but that was 15 years ago!!
I will see if I have any here at home left over from the saddle shop, but I doubt it!!!
PostPosted: Thu Jul 15, 2010 12:01 pm
Any time I have dealt with "closed cell" foams it was in the way of gaskets and it was in the specs as "closed cell" so it would not pass liquids I have no idea how water proof it was but it was not open cell like a sponge was.
Foams come is all kinds of different densities and many seats use different densities stacked up to give different supports.
