It is currently Thu Oct 31, 2024 8:39 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 02, 2008 11:13 pm
Turbotexas wrote:
Can someone tell me where the dang idle adjustment is??? also air screw??? My son has this junk on his new bike and I haven't figured out how to swap out to a kiehan yet???
He races this weekend so help is appreciated!!!
Their is a thumb screw on the side for the idle and you need a screwdriver for the air screw..
I'll look again, I had to take the seat and sub-frame and top shock bolt to get to the bottom of this carb in the Aluminum framed bike??? Some one at Honda messed up....LOL No not really I just don't have the Manual yet for this bike!!! I think I saw the extremely small air screw but will have to buy a small screwdriver@!!! LOL
 Post subject: Re: Mikuni TM 38mm CSI
PostPosted: Sat Jan 01, 2011 8:35 pm
I just rebuilt my 38mm TM carb for my Tecate.I had to replace the internals from the stock to accomendate the mod's I did motor (( Internal Combustion Engine ? )) wise.
I installed a 6fj40 needle replacing the stock 6fj41
I installed a 35 slow jet from the stock 20
I installed a 389-q6 needle and seat from the stock 389-q2
I installed a 370 main from the stock 230
The throttle slide was a 4.0 I kept that.
The throttle valve was a 3.5 I kept that.
These mods made such an improvement, it seems whenever you run these carbs they need to be custom built to the specs each individual needs for there machine,Buying 1 stock direct OEM might not be correct application.
