It is currently Sun May 18, 2025 2:30 am
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Jan 09, 2011 11:06 am
take a picture with the Bill's pipe as near as possible to fiting, we might have ideas...
PostPosted: Sun Jan 09, 2011 11:11 am
I will, when it warms a bit,but it is way off
PostPosted: Sun Jan 09, 2011 11:13 am
you askaird of the cold??? LOL I can't believe Ashville is that cold???
Had any Flocks of birds fall out of the sky there???
PostPosted: Sun Jan 09, 2011 8:42 pm
One of the members of this site is related to Bob Briggs old mechinic/fabricator.I forget who it is but he has a thread started on a buggy he had just bought when he discovered who his uncle(I think) was.Might be one of the earlier briggs?Try searching for briggs maybe you can find this guy.He could be a big help in figuring out/setting-up these engines you have.Just a thought.
PostPosted: Sun Jan 09, 2011 8:56 pm
Here it is , viewtopic.php?f=5&t=5250&hilit=briggs
Start on the first post on page 4,then scroll down to somewhere after the pics,some good info there for you.
Hmmm..link didnt work,this is the title of the thread-EEE Stadium Lite!
Link fixed by hoser you had a comma too close to the link at the front end then had a period behind the link this kills the link....
PostPosted: Sun Jan 09, 2011 9:57 pm
I know the thread you are talking about,I have read it,
I finally got the number for one of the guys that was in on the building and fabbing of these motors!
HAPPY DAY! :-)
Anyway,
The ody is all together but the plumbing,Waiting on my rad.
charging the bat tonight
will double and triple check everything tomorrow
compression test
sqish test
just for the hell of it,I tried to pull the start rope...WOW...BIG difference from a stockish motor (( Internal Combustion Engine ? ))! :shock:
cant wait!
PostPosted: Mon Jan 10, 2011 9:21 am
HAPPY DAY! :-)
Anyway,
compression test
sqish test
cant wait!
I cant wait, I have seen these engines run in stadium lite cars against full modified long travel Pilots they RUN! The cars they were in were close to 700 lbs too.
PostPosted: Mon Jan 10, 2011 10:13 am
bullnerd wrote:
Here it is , viewtopic.php?f=5&t=5250&hilit=briggs" ."..
Thanks Boss!
PostPosted: Mon Jan 10, 2011 12:08 pm
Last night I talked with one of the guys that was into this whole thing
Looks like we have 2 different motors
Briggs built and Rennie Awanna built{used to race with Jimmy Johnson!}
Nature's Recipe stadium lites ..these were the best out there they say
anyway, my 420{400} was built by Rennie
tons of low end torque{teeth chattering} is what I was told
these motors will in fact last a whole racing season without any issues
given the right maint. and running them FAT!
,these were beat to death when we got them though..Go figure!
My 360 topend was done by someone different,someone that had to do with Rennie,I will have more info on that today!
I will have alot more info in the next few days
Ed
PostPosted: Mon Jan 10, 2011 1:01 pm
Ed
You get all the details on the Engine bore, stroke, piston mfg., cylinder sleeve part number, rod part number, any mods done to the cases or crank in case you have to replace them, port timing info, compression ratio info. ?
PostPosted: Mon Jan 10, 2011 1:46 pm
Will do!
PostPosted: Mon Jan 10, 2011 9:15 pm
Ok,guys I got a few more details today
plus a vintage video
http://www.youtube.com/watch?v=h2wGFwV5S1Y" ."..
Details on the Rennie 400
turns out, my motor (( Internal Combustion Engine ? )) has a few goodys added to it
kawasaki KX 500 exhaust port and intake
KX 500 reed cage
cr 500 style head
mikuni watercraft pumper carb{ will stay running even when rolled over on rollcage!..LOL}
wiesco yz 490 piston shaved a bit
standard honda rod
same set up as in the rennie car in this video{might be the same motor (( Internal Combustion Engine ? ))}
88.5 mm bore
standard crank..cleaned up a bit and pinned
sleeve from northwest sleeves
stock bearings..doubled up
avg compression between 170 and 180 psi
lowerend,studs relocated for the kx 500 stuff
custom cases to house the extra bearings
spacer plate for timing
This motor (( Internal Combustion Engine ? )) is built to run about 8000 to 8500 rpm with lots of low end torque
should be clutched at about 5500 rpm stall to perform best
avg price to do this motor (( Internal Combustion Engine ? )) back then,with the man hours involved... was about $5k
The good news is I may have found a couple of more of these motors to be bought!
lots of parts too!
still getting more details on the 360
I do know this,it was a stadiumlite race motor (( Internal Combustion Engine ? ))
and very nasty too, in the video,car number 7 is BV racing same head as mine
should really be a beast in the ody!
But I have to do some more digging!
PostPosted: Mon Jan 10, 2011 10:18 pm
I remember reading there was some yz490 parts in there somewhere.
Very cool stuff,thanks for sharing.
PostPosted: Tue Jan 11, 2011 12:06 am
pretty cool vid that you found. the motor (( Internal Combustion Engine ? )) in an oddy will be a demon
PostPosted: Tue Jan 11, 2011 10:58 am
Well, My goldwing radiator should be here today,along with the rest of my 450r a arm conversion stuff!
Turns out my battery is DEAD!,so..need to pick one up...
and I am still needing shifter cables,thought I had them,,,but the deal fell through{anyone have a set?} cash or things to trade
If everything goes well today I should be able to fire this baby up!
I have some electrical stuff to play with today..custom racing CDI (Capacitor Discharge Ignition) to install along with some gauges..EGT and water temp
P.S.
I should have a list of high performace 350/400 parts for sale on thurs night..from a friend of mine
all race parts from the stadiumlite cars
maybe a couple of motors too
Ed
PostPosted: Thu Jan 13, 2011 4:50 pm
Got a little done,Its hell worken 12's and getting anything done!
anyway, the fleabay radiator...86 goldwing
and that nasty looken exhaust
took them to work.. sandblast and a good air blow.... and then some high heat paint
and all new hardened bolts
I will get installed this weekend
wasn't even any pitting on the pipe!
I will be running an electric pump with a thermo switch for the fan..COOL!!!!!!!!!
and another update
The 360 top end was done by a guy named Bob Victoreno..BV Racing
They ran very good from what I am told
We will see
PostPosted: Thu Jan 13, 2011 7:55 pm
Keep up the good work Kuda, that pipe looks brand new. I cant wait to see the end results so lets try to speed things up slacker.
PostPosted: Thu Jan 13, 2011 8:01 pm
No doubt... complaining about 12 hour shifts??? Cant be too tough since he gets to bring parts to the job and work on them there!!!
PostPosted: Thu Jan 13, 2011 10:24 pm
Very nice Ed...what I want to know is, whats the picture on the rug??? :-) :-) :-)
PostPosted: Fri Jan 14, 2011 9:45 am
I know,I know, Hope to Fire her up this weekend!
I will be working on the plumbing and getting her wired today
PostPosted: Sat Jan 15, 2011 5:45 pm
IT LIVES!!!!
Lots more work to go though
gonna get her plumbed tonight
click on pic to play
well Im off to lowes
PostPosted: Sun Jan 16, 2011 5:18 pm
plumbing is roughed in, running very cool
I guess its time to pretty it up a bit now
plug chops, wire my egt and temp
I need to work on the idle a bit also,
Quick question...
Is it normal to smoke as much as it is?
running full syn oil at 32 to1.
http://www.youtube.com/watch?v=GXbl1jC0_4g" ."..
PostPosted: Sun Jan 16, 2011 10:59 pm
If your jetting is rich or if it is cold it will smoke like you are running a mosquito abatement smoker! LOL :-)
It will smoke little or not at all once jetting is dialed in and up to operating temp.
PostPosted: Sun Jan 16, 2011 11:13 pm
Until he runs it under load and cleans out the fresh bottom end it will smoke while idleing...
PostPosted: Tue Jan 18, 2011 11:42 pm
sounds really good though. Keep up the good work.
Registered users: c5racer, Google [Bot], Lanix, liduno
