It is currently Sun May 18, 2025 4:28 am
PostPosted: Mon Jan 31, 2011 1:08 pm
davidafco sent me his Pilot Engine for a CSI.
Some over all pics before disassembly, has the classic build up of Mid West mud, you know the stuff that etches itself into the aluminum and is about impossible to clean, also can see the exhaust was leaking.
DSC08355.JPG [78.9 KiB]
Downloaded 173 times
File comment: Bottom side
DSC08356.JPG [71.68 KiB]
File comment: Exhaust leak yummy
DSC08357.JPG [88.65 KiB]
PostPosted: Mon Jan 31, 2011 1:10 pm
Peak in the cylinder
DSC08359.JPG [57.09 KiB]
Downloaded 172 times
File comment: Jetting plenty rich
DSC08360.JPG [101.56 KiB]
DSC08375.JPG [71.51 KiB]
DSC08377.JPG [75.23 KiB]
DSC08378.JPG [75.45 KiB]
DSC08379.JPG [67.47 KiB]
PostPosted: Mon Jan 31, 2011 1:11 pm
See the wash affect on the head?
DSC08361.JPG [103.59 KiB]
PostPosted: Mon Jan 31, 2011 1:13 pm
Crank cases split.
So far everything looks good, crank and rod in good condition, cylinder just needs a hone, crank bearings and seals, piston, rings, etc will be replaced.
DSC08367.JPG [67.27 KiB]
Downloaded 171 times
DSC08372.JPG [69.75 KiB]
DSC08374.JPG [64.55 KiB]
PostPosted: Mon Jan 31, 2011 7:12 pm
Parts have been ordered. If something is backordered I will let you know asap. That dirt was from a old stripper pit in southern Indiana where I use to run it. Not a large area but was fun :-) What is that washing you mentioned?
PostPosted: Mon Jan 31, 2011 7:46 pm
See where their is no black (carbon) on the head that is where the fresh fuel charge has washed it off, notice where the clean area is that is the rear of the Engine, look at the cylinder see where that rear port opening is aimed up towards the head?
See the green spray up to the head in the animation, its job is to sweep and follow the products of combustion out the cylinder and into the pipe where the returning pulse wave in the pipe forces it back into the cylinder before the piston closes the exhaust port.
PostPosted: Mon Jan 31, 2011 7:53 pm
oh ok I see what your talking bout. So I take it that isnt a bad thing then. From the looks of things would you say the Engine was getting the right fuel air mix? Not to lean or rich
PostPosted: Wed Feb 02, 2011 3:16 pm
I don't see any spooge??
PostPosted: Wed Feb 02, 2011 7:40 pm
The right crank bearing and gasket kit are no longer available from service. Tried call odysee salvage today but the snow was to much. Answering machine said will be there tomorrow. If he cant help then its the evilbay I go.
PostPosted: Wed Feb 02, 2011 7:49 pm
I believe ATV racing have the parts you need.
PostPosted: Thu Feb 03, 2011 8:33 pm
Wasn't there a posting here from Stoneman or Mikey on replacement bearings?
PostPosted: Thu Feb 03, 2011 8:41 pm
viewtopic.php?f=1&t=8696
