It is currently Thu May 15, 2025 12:02 am
PostPosted: Mon Jan 31, 2011 9:00 am
Bubba66 stopped by and dropped off his 350 basket case Engine, he can give the details on this basket case project I don't know all the little details.
The Engine looks to be in pretty good shape.
So far other than the missing head nuts everything seems to be here to build up a complete Engine I will find out for sure as I assemble.
PostPosted: Mon Jan 31, 2011 9:03 am
The cylinder looks good some minor scuffing from dirt but its not bad the as found piston to cylinder clearance was .004 just a little on the tight side for a 350 Odyssey Engine.
PostPosted: Mon Jan 31, 2011 9:06 am
The piston looks like it only has a few hours use on it other than the scuffing from the dirt no real wear, it will be reused, their was some slight scuffing on the bridge the bridge was not properly relieved in the cylinder this will be corrected before I assemble.
I will polish up that scuffed up area, relieve the bridge then finish hone the cylinder to a clearance of .0045.
PostPosted: Mon Jan 31, 2011 9:07 am
One side on the exhaust side of the piston also had a scuff mark it will be polished too.
PostPosted: Mon Jan 31, 2011 9:09 am
Intake manifold hard as a rock as usual, reeds look almost new.
PostPosted: Mon Jan 31, 2011 9:11 am
Parts are on order more once I get the parts, lots of gasket scraping and cleaning to do.
I will mod the cases for better bearing lube like I do on the Pilot cases, gotta figure out what balancer case mod we will do, going to open up the starter to see what its condition is you can see some oil on the outside hopefully the inside is not full of oil.
PostPosted: Mon Jan 31, 2011 10:59 am
I find that pic of the bridge wear marks,over the cooling/lube piston holes interesting.
It's tapered,not even? The piston must be rocking forward/backward on it's stroke?
Or is it the ring that keeps it away from the bridge?
PostPosted: Mon Jan 31, 2011 11:55 am
Look at the bridge on the cylinder pictures I gave the cylinder a light hone with my ridged hone, you can see the rub marks and see the cross hatch from the hone on the bridge, they never did anything to the bridge so when up to temp and the bridge expands into the cylinder it put the rub marks you see on the piston.
This is a good example why the bridge needs relieved as well as the holes drilled.
PostPosted: Tue Feb 01, 2011 2:20 pm
Stix has some head nuts for me. He's gonna send them as soon as he can dig himself out. Thanks Marc. Everything else is on it's way for the motor (( Internal Combustion Engine ? )). Took some pics with the iPhone but can't figure out how to attach them from here. Have to put them on the laptop after I get done plowing.
PostPosted: Tue Feb 01, 2011 2:25 pm
Thanks Stix for helping a brother out with the parts!
Not sure you can upload pics here from the iphone or not.
Plowing ? you have that much snow already, we only got about 3/4" since yesterday, currently its not showing here but strong NE winds looking at the weather channel it looks like we will see snow at about 3pm CST
PostPosted: Tue Feb 01, 2011 2:59 pm
I won't get out plowing for a while. Got a sick kindergartner and Momma is at work. The big snow is just starting now. You should be getting it before me. Talked to Lonerider this morning and he's up by Ohare. That would suck.
PostPosted: Tue Feb 01, 2011 3:17 pm
Whats he doing by Ohare don't he watch the news/weather lol
PostPosted: Tue Feb 01, 2011 4:01 pm
They moved his office up there. It would probably be in his best interest to knock off early today.
PostPosted: Tue Feb 01, 2011 5:19 pm
Wish him luck going home that will be a real mess.
