It is currently Thu May 15, 2025 10:56 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Mar 22, 2011 10:47 am
pilotpete1 wrote:
pilotpete1 wrote:
what the part number of the tranny bearing??? i will get him to check......
Here are some post on the subject
viewtopic.php?f=1&t=3004&start=40" .".." ."..
viewtopic.php?f=1&t=7090&view=next" .".." ."..
Ok i have them in stock ,so should be able to get them matched also.......
Sizes and prices?
How long to ship to the USA on average?
PostPosted: Tue Mar 22, 2011 5:53 pm
I want in for a few myself.
PostPosted: Wed Mar 23, 2011 5:00 am
sorry guys not had a chance to see the guy but have a day off tomorrow so will go and see him and will get prices.....
PostPosted: Thu Mar 24, 2011 12:25 pm
Update?
Any luck?
How many we need to buy to get price breaks?
I know of two guys needing them I would take one myself, I know every Pilot owner needs to buy at least one if they are smart so when the day comes they need one they have one.
PostPosted: Thu Mar 24, 2011 3:58 pm
i went to see him today, told him about 100 sets hes going to ask his surplier, come back to me next week with a answer.....
PostPosted: Thu Mar 24, 2011 4:07 pm
Thanks,
Just to confirm this would be for the 6306/32 bearing? This is a C3 bearing..
Again thanks.
PostPosted: Thu Mar 24, 2011 4:36 pm
Is he pricing the tranny bearing? Both sides of the input shaft are specials. One side is still available fron Honda the last time i looked but only a few left.
PostPosted: Thu Mar 24, 2011 5:23 pm
IF you have the bearing numbers and sizes please post them up might as well see about getting them that may help with the prices also if were ordering 3-4 different bearings at a time?
PostPosted: Thu Mar 24, 2011 5:29 pm
Pete stated he had the tranny bearings in stock earlier in the thread. Pete if you need any info let me know.
PostPosted: Fri Mar 25, 2011 5:12 am
yes he looking into fag bearing for both sides.....i forgot about the trany bearing will get them sorted next week also......
PostPosted: Fri Mar 25, 2011 9:47 pm
Looking on this page their is a OEM bearing that will work? http://www.tjb-bearings.com.tw/en/japan/NISSAN.html" .".." .".. Click on page 118
Someone have a Nissan dealer close they could run them OEM numbers?
OEM number 43215-G8100 is the KOYO=6306/32 2RS it would be a sealed bearing we could knock out the seals remove the grease, question is, is it a C3 clearance bearing?
Also the OEM number 43215-H5000 is a NACHI=6306/32 2NSL no idea what the 2NSL means maybe it has a snap ring around the outside?
Be nice if we could find these at a local Nissan dealer.
I see ATVR is selling them on ebay, not sure if the bearing in the pic is what your getting but it has 12 balls, that would be better distribute the load better than 8 balls? What about getting 12 balls for the clutch side bearing, stronger? Wonder if that is a 6.00 made in china bearing pimped up to be a US $64.95 evilbay bearing, maybe they bought it from a Nissan dealer? http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=" .".." ."..
PostPosted: Mon Apr 11, 2011 6:05 pm
Found online for 35 bux
http://www.mynissanpartstore.com/partlo ... eid=214102
Part number 43215H5000 Universals & rear axle - Rear axle - Axle bearings Axle bearings, 200sx - link type suspension 1984 - 1985
Universals & rear axle - Rear axle - Axle bearings Axle bearings, 810/maxima - link type suspension 1984
Front suspension - Carrier and front axles - Bearing Bearing - 4wd 2000 - 2004
Attached a print screen if link fails
Nissan 6306-32 bearing.pdf [77.73 KiB]
Downloaded 166 times
PostPosted: Mon Apr 11, 2011 6:13 pm
Looks like another application 1984 to 1989 300zx 430 rear axle.
http://www.courtesyparts.com/300zx-part ... _2415.html
PostPosted: Mon Apr 11, 2011 7:43 pm
I ordered 2 of these bearings for my 2800 Pilot motor (( Internal Combustion Engine ? )) CSI(if needed) and shipped them directly to Hoser. We will see if they work well or not.
PostPosted: Thu Apr 21, 2011 1:57 pm
Update
The two bearings Mudbogger ordered are here they came in a bag that has two smaller bags that have a Nissan label on them.
This is a replacement for the now discontinued Honda 91033-HE0-005 right crankshaft bearing.
Ordered the bearings from http://www.mynissanparts.com
Part number was 43215H5000
Description Axle bearings, 200sx - link type suspension 1984 - 1985
Price $34.86 Each
The bearings are sealed on both sides the seals will be removed the grease removed then oiled with two stroke oil.
Numbers on the bearing are
On the rubber seals it says
NTN 6306U JAPAN
On the bearing race the numbers are
JAPAN 15C-4 100828 0757 NTN 6306/32C4 Assume the C4 means the bearing is a C4 clearance?
On the other side of the bearing on the race it says just
/32
Thanks Mudbogger
PostPosted: Thu Apr 21, 2011 2:12 pm
Popped the seal out with a pic they come out easily, over the years I have removed seals from bearings like these and repacked them, others I cleaned out the factory grease and repacked them with a high temp high speed grease for different applications, these seals will be thrown in the trash..
See the /32 that is the back side of the bearing, other pic shows numbers on the front side.
Everything I see about these bearings seems like quality to me I will be using them in my Engine unless someone else can give me a reason not to.
PostPosted: Thu Apr 21, 2011 2:47 pm
rmesser wrote:
In the first link you list here these were ordered by Kartman1 and shipped to me for inspection first the bearings are some cheap ass bearing that was made in CHINA the only writing on them was CHINA the second problem is BOTH bearings were the same size and were for the LEFT side they are just a cheap made in china 6306 bearing you can buy all day long for 4.00 to 6.00 the seals were the correct OEM Honda seals, bearings and seals were shipped back to the seller and a refund was received.
Next Kartman1 ordered the bearing from ATV Racing link and had shipped to me, its clearly a bearing that had seals and they removed them they didnt remove the grease, I have no idea where they found the bearing I can only assume its for the same application I found for a bearing of the same size, rear axle bearing for a Nissan automobile.
The bearing appears to be of high quality made in JAPAN it was cleaned and lubed with 2 cycle Engine oil and installed in his Engine, I would not hesitate to try one of these in my Engine, note the bearing only has 8 balls NOT 12 balls like in the picture ATV Racing uses in their evilbay advertisement nothing pisses me off more than when someone charges you top dollar for something then is too lazy to take a picture of the exact product they are selling you, well they fooled me I thought I was getting a heavier duty bearing than OEM based on their description and the EXTRA BALLS in the picture, coupled with all the problems I have had with ATV Racing in the past its hard to respect a business like this.
DSC09090.JPG [80.39 KiB]
Downloaded 30 times
DSC09091.JPG [83.51 KiB]
Downloaded 30 times
File comment: Here is the picture of the bearing ATV Racing had with their evilbay ad.
PostPosted: Thu Apr 21, 2011 2:59 pm
nice write up hoser - thanks
nachi bearing.....$28.00 http://www.carpartsdiscount.com/auto/pa ... 3593=82502
even on ebay..... $ 50.00 http://cgi.ebay.com/ebaymotors/NEW-Niss ... ccessories
PostPosted: Thu Apr 21, 2011 3:00 pm
How many balls are in the Honda oem bearing?
PostPosted: Thu Apr 21, 2011 3:07 pm
Good question 8 balls as seen in the pic, pic is of actual bearings removed from a Pilot
PostPosted: Thu Apr 21, 2011 3:09 pm
I will be ordering 2 bearings from the same place Mudbogger got his they came in the OEM Nissan package, then I know I am not getting some repackaged CHINA 6.00 bearing :-)
PostPosted: Thu Apr 21, 2011 4:44 pm
Hey Hoser
do you want me to send you a FAG bearing for CSI?? i bought 2..... i used one on a 500 Engine i just built but would be happy for the other to go to someone who's willing to try it out ......i'm going to ride my new 500 every day (well every dry day not sure how much that will be living in the UK LOL)
i have tried to get a price for 50-100 bearings from the dealer but he told me FAG are very busy at the moment and getting a price and ETA is going to be hard to get?????
PostPosted: Thu Apr 21, 2011 5:58 pm
pilotpete1 wrote:
Hey Hoser
If you have a FAG bearing I would be willing to try one out (wow that sounds kinda GAY huh haha) I have never heard anything bad about FAG's before (ball bearings that is) and only good things send me a PM we can exchange info (sounding GAY again geese) I am willing to pay for the bearing too (you know some mutt is thinking prostitution about now)
PostPosted: Thu Apr 21, 2011 6:16 pm
You know if this was craigslist the cops would already be at you door.........
Have you looked at the Timken RW132 or TMRW132 or the SKF GRW132 bearings?
PostPosted: Thu Apr 21, 2011 8:23 pm
Hoser, check you PM'S please, info sent. :-)
