In original state, this FL350R basically needed...
1. Top end job
2. Carb clean
3. Battery
4. Starter rebuild / replace
5. New front tires
6. Clean-up
7. Re-assembly
8. Repair front bumper
9. Salvage the fenders; repair where needed
But I ended up doing...
1. Top-end job, 80mm bore/hone, Wiseco piston kit, piston drilled, ceramic coated dome, teflon coated side/skirt
2. Exhaust bridge relief and very light port work (defect removal basically)
3. Crank case vent plug and re-locate mod
4. New crank shaft seals
5. Replaced needle bearings in the gearbox; replaced seals.
6. Water-cooled head (After$hock) with YFZ450 radiator/fan, Mercedes pump, and Honda overflow tank; new electronics/wiring to match; custom mounts for everything.
7. New Mikuni fuel pump
8. Cleaned carb; bought +/- jets and 10-pk of plugs for tuning
9. Custom homemade steering wheel pod with Trail Tech Vapor, EGT gage, voltage gage, and fan & water switches.
10. Replaced the rear upper links with brand new aftermarket hardware (QS Components out of Indiana).
11. Picked up a better set of rear rims with damn near new Ohtsu tires, and custom offset front wheels with damn near new tires.
12. New bulbs for stock headlights.
13. Had to buy the side panels for the column.
14. Tore the stock front bumper down to the single tube and built a nice dune-buggy-ish front bumper out of some spare tubing
15. Sand-blasted the
Engine mounts, covers, plates, etc. and painted black (would've p-coated if I had the p-coat stuff at that time).
16. Removed axles, inspected, and repainted with silver Engine paint; baked on with my heat-gun
17. New throttle cable.
18. Some pipe insulation pads here and there.
And my plans for this buggy are...
1. Install the brand spanking new-in-the-plastic-bag fenders on her, but remove them for riding (lol) (DONE)
1.5. Crack open the Engine and make 100% sure all is well, clean, and beau-tee-ful. (DONE)
2. Start her up and tune, tune, and tune. (DONE, needs tuned)
3. Fab a steel mesh "visor"
4. Fab a set of bolt-on tree-bars
5. Install my reverse light and cab light
6. Install a set of round dune buggy headlights (CANCELLED...restored stock rectangles to perfection from bulb to outer rubber seal)
7. Install a fire extinguisher and mount (DONE)
8. Make a mount on my gage pod to mount my phone (for camera and GPS).
9. Buld the visor for my gage pod
10. Powder coat the wheels (DONE)
11. Fab and install the additional link from the rear carrier to the frame (axle saver). Will be 5/8" threaded rod with 5/8" ID tubing through the middle, then a 5/8" heim at either end.
12. Side panels on interior; either steel mesh or aluminum sheet.
13. Basically get this one setup and tuned for trail / woods / snow riding, dependable, and fun.
14. Some more aesthetics along the way.
Then focus on buggy #2. #3, and #4 (will have their own build logs).
