It is currently Sat May 17, 2025 8:27 am
 Post subject: snorkel to frame bracket
PostPosted: Mon Apr 09, 2012 11:35 pm
Hello. I am doing the dual snorkel intake mods to 3 of my FL 350 Odysseys and am in need of 2 of the brackets that hold the hose to the frame. I have been lurking around this site for about a month now learning all I can about the FL350. Any help would be appreciated. I tried the number for Triple E and it was disconnected.
I just bought 4 of these about a month ago and am having a blast with them. I took them to the Oregon dunes last week over spring break and they ran like a champion with the air box lid removed and would not run well at all with the air box lid on.
Thanks!!!
Dave ::-:
PostPosted: Tue Apr 10, 2012 10:44 pm
Anybody know where to purchase stock clamps for the snorkel tube?
PostPosted: Wed Apr 11, 2012 9:44 am
Can you post a picture or a part number or both I have an idea what your looking for but not wasting a second more time until I know exactly what you want I don't even know why I wasted my time asking you more info..
HELP us to HELP you :shock:
PostPosted: Wed Apr 11, 2012 10:53 am
I believe he is looking for.....
17318-VM0-770
Which is discontinued.
I just use velcro strips to hole the hose to the frame. They work well and are easily removed when you need to do work on the intake system.
WARNING! I you are going to ride in the sand with the air box lid off, you might as well buy parts to rebuild the Engine after every trip out. Sand is very abrasive and will destroy an Engine quickly. If the Engine runs better with the air box lid off then you need to re-jet your Ody for the altitude you are running.
PostPosted: Wed Apr 11, 2012 1:18 pm
Thanks for the tips! I ran these Odysseys for a week without the lids on and they still seem fine. They are all totally stock and on original 27 year old pistons. I am in the process of the dual intake mod. I will only be running them at sea level, Oregon dunes. Air is between 50 and 68 degrees most all year.
The bracket that holds the tube to the frame is exactly what I'm looking for..
Thanks!
PostPosted: Wed Apr 11, 2012 1:52 pm
Please carefully pull the air filter and look into your intake tube that goes to the carb with a light the tube should look like brand new shiny black rubber, then take a white paper towel and wipe the inside of the tube see if you get in dust.
That sand is a killer even with a fresh clean well oiled filter in place its also why we recommend you installing pre filters on your dual intake mod, you will love the dual intake mod BTW.
Hopefully it does not look like this. :shock:
Please consider removing the top end of your Engine and inspecting the piston sometime soon, 350's are notorious for breaking the piston skirts then the broken skirt getting wedges between the crank shaft and crank cases and punching a hole in the bottom of the Engine, it pretty much takes a 200.00 replace the piston job and turns it into a find another Engine or have the cases welded up job, replacing all the bearings, seals, gaskets pretty much 800-1000 dollar job
Cool thing about a 2 stroke Engine is it will run like brand new right up until seconds before it it locks up and needs hundreds of dollars in repairs its very rare you will get any indications its about to poofkaboom this is why Honda says in the manual to take it apart and inspect it every 30 hrs of run time.
Not trying to scare you or make you paranoid just share important info with you before not after :-)
Prefilter mod on other machines might be useful for ideas viewtopic.php?f=1&t=8929
More filter info viewtopic.php?f=9&t=5491
PostPosted: Wed Apr 11, 2012 2:17 pm
17318-VM0-770
Either #9 or # 18 in the pics? Service Honda shows them both still available
PostPosted: Wed Apr 11, 2012 2:28 pm
It's #18. I looked at service Honda this morning and it was listed as discontinued???????
PostPosted: Wed Apr 11, 2012 3:00 pm
Yes! #18!
Thanks for all the help!
Dave
PostPosted: Sun Apr 15, 2012 7:34 pm
both are hard to find items and discontinued. The #18 item is a rare restore piece these days. Never see them around.
PostPosted: Sun Apr 15, 2012 7:59 pm
Anybody have a picture of the actual part not sure I have seen one before
PostPosted: Sun Apr 15, 2012 10:15 pm
Hoser, it is the black bracket in this evilbay ad http://www.ebay.com/itm/85-1985-Honda-F ... 22&vxp=mtr
PostPosted: Sun Apr 15, 2012 10:37 pm
I'm finding everything for these things to be relatively expensive. At that price, I'll use the Velcro strap I was recommended!
PostPosted: Sun Apr 15, 2012 11:18 pm
Duneit i may have one in my parts pile somewhere. i wont be able to look until next weekend.. if i remember to lol.
PostPosted: Mon Apr 16, 2012 1:04 am
I have at least six complete sets of those in my stash somewhere, they're going on the 350's and pilots when I get a chance to finish the dual intakes, if I can dig them up in the next few weeks I can post a pic.
Registered users: Becerra, Bing [Bot], Google [Bot]
