It is currently Tue Apr 16, 2024 5:50 pm
PostPosted: Tue Oct 02, 2012 11:00 pm
FL350 Ignition system
Hi Guys, ::-:
I have an electronic copy of the factory manual. GOOD Stuff. However, It really is not 100% straight forward on the wiring for the starter, CDI (Capacitor Discharge Ignition), Solenoid and battery.
I'm just trying to get the ignition system wired back. Does anyone have the 007 pictures or diagrams I may be looking for?
Thanks!
MB
PostPosted: Wed Oct 03, 2012 9:52 am
Maybe its experience or how many times I've looked at it, but the manual schematic seems to make good sense.
What's your question?
PostPosted: Wed Oct 03, 2012 10:11 am
This?
Bigger version here http://www.pilotodyssey.com/2012/FL350electrical.jpg
PostPosted: Fri Oct 05, 2012 1:49 pm
Color PDF I've found.
FL350_schematic.pdf [72.41 KiB]
Downloaded 132 times
PostPosted: Sun Oct 07, 2012 5:58 pm
Thanks guys!!! I think I have my head around the wiring. I am trying to figure out what is wrong with the system.
1st off: no problems running it with manual pull start
when I apply 12V to the starter motorterminal it does not turn I'm guessing its bad?
I am trying to remove it but realizing it is wedged between the case and the bracket behind it. I wish I could get it out without having to dismantle half the Engine.... any tips?
PostPosted: Sun Oct 07, 2012 7:26 pm
I find it easier to take the rear brakes alose and let the disk drop down and pull it from the bottom. Hope this helps. Thanks Billy
