It is currently Mon May 19, 2025 3:37 am
PostPosted: Wed Jul 09, 2008 10:27 pm
Hello All
Well this project will be about rebuilding the rear bearing housing or Knuckle
Step 1 we will start by looking at the bearing area and how bad it is
Step 2 will be making a maching fixture to recut the bearing area
Step 3 will go through the welding process on the Knuckle
Step 4 will go through the machining process and assembly
Thanks for Looking
SpeedChaser :-)
File comment: slip gage to show ware right arm
File comment: side view right arm
File comment: right arm
File comment: center post for fixture
File comment: bottom plate and side support
PostPosted: Wed Jul 09, 2008 10:30 pm
next finishing up fixture
the fixture will gage off one side of bearing
so we can recut one side at a time
PostPosted: Thu Jul 10, 2008 8:42 pm
Speed-on the outer edge of each carreir the hub slides onto the axle and into the seal, you do not need the dimensions on the axle, hub, etc for anything correct, the seal itself should be enough since the hub itself slides into it correct?Heres a view of what I am speaking of from the rear of my PROJECT PILOT.I have a spare hub I can send over to you for fitment if needed.
PostPosted: Mon Jul 14, 2008 10:10 pm
Had some time this last week end
clean up pre heat and weld
File comment: blast up area to be welded
File comment: temp stick it melts at the temp stated
File comment: For this application I use 650 deg. temp stick
PostPosted: Mon Jul 14, 2008 10:17 pm
Time to get thing hot hot
File comment: You can draw with the temp stick like a crayon it will melt when hot
PostPosted: Mon Jul 14, 2008 10:29 pm
Well time to weld for this application
I am using silicon bronze filler rod for the build up of the bearing area.
It will mix with the cast steel housing and should not cause hard spots in the casting
File comment: 180 deg tig tourch
PostPosted: Mon Jul 14, 2008 10:38 pm
fixing the sloted bolt hole
File comment: hole all gone now
File comment: all welded up let them cool down slow
File comment: next
time to machine
PostPosted: Tue Jul 15, 2008 8:59 pm
Hello maching pic's
File comment: hole redrilled from other side
File comment: knuckel in fixture geting ready to be machined
File comment: close up
File comment: top surface cleaned up
File comment: first cut on bore
PostPosted: Tue Jul 15, 2008 9:04 pm
more maching pic's
File comment: more maching pic's
File comment: more
File comment: next
File comment: the Elongated hole that is round now
PostPosted: Tue Jul 15, 2008 9:12 pm
bearing alignment tool
File comment: time to make a bearing alignment tool
File comment: cutting tool on lathe
File comment: finsh cutt
File comment: Knurl the handel
File comment: finshed with bearing tool
the tool is a slide fit to the bearing
PostPosted: Tue Jul 15, 2008 9:28 pm
assembly of bearing and seals
File comment: tap fit on the bearing
File comment: found the bearing driver and seal driver 1-13/16 socket
File comment: fits the seal nice
File comment: next
File comment: tap one side bearing in to the bottom
File comment: don't forget the spacer
PostPosted: Tue Jul 15, 2008 9:34 pm
Hello speed I have a few questions. I never done that before so I was worndering if you have to heat the cast piece and weld while hot so the weld would take with out making the cast brittle or is do to the thickness of the cast piece. My welds always look all hacker like, I mean like a bubble gum patch. Next question would be heating it up like that would it cause any warping of the piece or is that the reason for slow cool down.
I really enjoy watching you work. It make me want to go get new tools but I woudn't know how to use them. I quess I will just druell for know. By chance close to wichita ks I like tours.
Thanks for any input you throw my way. Sometimes just knowing the right way and why makes the biggest diff.
PostPosted: Tue Jul 15, 2008 9:37 pm
next
File comment: Checking ailment
File comment: installing seals
File comment: next
File comment: other side
PostPosted: Tue Jul 15, 2008 9:41 pm
all done and Ready to ship
File comment: all bag up
PostPosted: Tue Jul 15, 2008 10:04 pm
Sweet!
No painting included with that service?
Hee Hee
PostPosted: Tue Jul 15, 2008 10:09 pm
nice work!
where do i send mine?
PostPosted: Tue Jul 15, 2008 11:10 pm
Speed-I am in awe of the work you have done-thanks so so much for the great write up and workmanship on the carriers, you have started to provide the group with your talents and I hope in the future others will use your services and products, it is refreshing to see someone of your talent and caliber help out the POOA COMMUNITY.
I can't wait to see what is in store for us next-!!!!!!!!! :-)
PostPosted: Wed Jul 16, 2008 8:07 am
DITTO!!! I could not of said it better!!!
Perhaps a longer rear axle for the fl350???
