Anybody that has read "800 Reasons why you need to take your axles out and inspect thesplines" article probably tried to remove their axles only to find out they are stuck and your not getting lucky like I was in getting your old ones to come out, I will give you a list of thinks to try but first I want to make sure you understand that this will take time and Patience, if youre short tempered and impatient plan on spending some big bucks. First you need to buy some PB Blaster, this stuff is incredible at getting things that are rusted together apart but you have to allow it to sit a few days after being applied, I suggest you tip your Pilot up on its left side and fill that cavity between the seal and stub shaft and let it as long as possible spraying it each day and tapping the CV housing with a small hammer, Remember tap because any time you are taping on that stub the bearings inside the transmission are taking all the beating, something a roller bearing was not designed to do. If you get lucky after a few days of soaking and taping you might get one to move and actually come out, if not now your going to need to take apart your inboard CV joint so you can access the inside of the stub axle shaft, turn to the page in your service manual where it shows taking apart the CV's to inspect and replace the grease. Once apart and all the grease removed you need to drill a 1/8" hole down the center of the axle, take your time and get it right down the center a stub shaft cost about 180.00 so you dont want to screw it up, once you get the hole drilled spray it with PB Blaster again filling the CV cup about 1/4" deep and keep tapping on the CV cup with a small hammer to make the PB Blaster work its way into the hole, you will also want to be tapping the CV joint opposite of the one you drilled since the PB Blaster is not reaching that side. I think it was Radical that made a slide hammer that attaches to the outside of the CV housing you might see if you can beg and borrow it from him at this point. If just the PB Blaster is not working you will need to drill the hole out to 1/4" so you can get a punch in the hole and try to drive the opposite side stub shaft out, keep in mind you get to abusing the punch in a fit of rage and bend it you will now not only have a stub shaft stuck but will also have a punch stuck in the stub shaft. Other things you might want to try before destroying one of the stub shafts is to take an air impact hammer and buy the hammer chisel attachment, they deliver about 500 blows a minute and run off of air, work it from every direction and just let it sit there and hammer for an hour or so.You can buy one of these at Harbor Freight 1/4" punch wont get it out? Now you will need to drill the axle out to 5/16 or 3/8 and use a larger punch and hammer.When you get to this stage of the game plan on replacing the stub shaft and after beating the hell out of the bearings in the transmission plan on replacing them also.
PB Blaster Penetrating Catalyst is great stuff!
