It is currently Mon May 19, 2025 7:17 pm
 Post subject: Pilot steering column
PostPosted: Fri Nov 23, 2012 8:09 pm
I'm doing a bunch of work to my pilot now so I just decided to do anything that needs
To be done..my steering column/steering shaft have alot of slop in them..is anybody have any technics to fix that? Cause I looked at getting a bushing and I think all the wear is in the shaft cause there is about 1/16inch indent along the bottom end of the shaft..what should I do?
PostPosted: Fri Nov 23, 2012 9:13 pm
http://www.pilotodyssey.com/steeringbushing.htm
http://www.ebay.com/itm/Honda-pilot-fl4 ... 19d018e0ef
PostPosted: Sun Nov 25, 2012 10:26 am
i was looking at getting the pilot steering bushing on ebay. is there an old bushing that needs to be taken out or does it just slide in?
PostPosted: Sun Nov 25, 2012 10:40 am
http://www.google.com/search?q=steering ... dyssey.com
PostPosted: Sun Nov 25, 2012 11:06 am
i read through all of it...do i need to take an old bushing out?
PostPosted: Sun Nov 25, 2012 12:26 pm
If you are replacing the bushing then the old one needs to be removed. It's a press in fit. Should be able to tap it out.
On my fl250, years ago, I built up the worn area with my mig welder then had it turned to the original diameter.
Anyone know if speed ever made a replacement bushing? I would rather deal with speed then the eBay guy.
