It is currently Fri May 16, 2025 12:01 am
 Post subject: Fl350 Conn rod
PostPosted: Sat Aug 29, 2015 7:42 am
Got good factory connecting rod with new crank pin and bottom bearing but need thrust washers where to get?
 Post subject: Re: Fl350 Conn rod
PostPosted: Sat Aug 29, 2015 8:48 pm
I think Lee had this same problem a while back but I cant find the discussion on the thrust washers perhaps someone else can.
PostPosted: Sat Aug 29, 2015 8:49 pm
Other thrust washer talk viewtopic.php?t=7184
PostPosted: Sat Aug 29, 2015 9:08 pm
Is this the one ??
viewtopic.php?f=1&t=14655&hilit=thrust+washer
A lot of the links in that thread are dead now but the one from summit looked good.
Don't know if summit ever sent Lee the washers as the thread died.
PostPosted: Sat Aug 29, 2015 11:38 pm
OK so bad news cleaned up rod bottom bearing good top of rod has small crack at top bearing who has good rod kit for these engines? Who is best hot rods prox weisco?
PostPosted: Sun Aug 30, 2015 12:09 am
I ordered the ProX 03.1315
From what I read here it is so far the best one. Comes with two different size shims. Pin is shorter than the stock oddy (I believe 5mm), no you cant use the old oddy pin even if it looks ok. Also the big end will smack the bottom end so you have to remove some from the end of the rod with a belt sander. There are a few threads here if you want to read up -- lots of info out there.
Have not installed it yet (winter project). You will need a minimum 30 ton press but 50 ton better from what I have read. You need some skill to do this job. FL350 right ??
PostPosted: Sun Aug 30, 2015 12:32 am
Yes was hoping speedchaser might do it for a donation also found a wiesco pin 65 mm long would need to be cut to 62 I believe. Engine still running good but making lil noise have 2 extra cranks one needs rod go ahead and do it I think that way can get buggy 2 going with Hillside Honda water cooled head
