It is currently Sun May 18, 2025 12:36 am
 Post subject: Pilot top speed
PostPosted: Mon Oct 29, 2007 8:43 am
Is top speed of a pilot limited to the ratio in the trans?
If you have 2 pilots one stock, one worked - will their top speeds be the same?
Keeping in mind they are both running same size tires and same transmissions?
 Post subject: Re: Pilot top speed
PostPosted: Mon Oct 29, 2007 8:50 am
Yes the clutch ratio and gear ratio in the trans will set the top speed.
If one Pilot is modified and will turn more rpms it will have more top speed.
My 440 Pilot Engine will turn 9000 rpm, it can be modified to turn 10500 rpm, I can install a smaller driven clutch if I wanted another 15 mph, I also can install a ROTAX drive clutch that is slightly larger in diameter for even more top speed, I have seen no reason to perform any of them mods..
PostPosted: Mon Oct 29, 2007 9:00 am
Thank You for this valuable info :-)
PostPosted: Mon Oct 29, 2007 1:30 pm
Why, do you want to go faster? LOL
PostPosted: Mon Oct 29, 2007 3:33 pm
The "modified" pilot would get there quicker, and then there is the CDI (Capacitor Discharge Ignition) rev limiter mod...
PostPosted: Mon Oct 29, 2007 7:06 pm
Thanks T - If my jetting doesn't do the trick....that just may be it. I may have to invest in a tach - Anyybody got a honda one?
PostPosted: Wed Oct 31, 2007 11:48 am
I am going faster....lol...I got hoserized
i put that 38mm carb on resently, plus the port and polished, 25 over shaved head, pipe, air box and clutch. I may even be becoming a better driver :-) lol
U wanna race....LOL
When you free for an epic PA run...I think it's time for the fast boys to hook up again....Hare? NJrider? ...whatta ya say?
PostPosted: Wed Oct 31, 2007 11:49 am
Hey Hoser? Can this be the top end bog I'm gettin?
PostPosted: Wed Oct 31, 2007 3:14 pm
It could be, without a tach who knows I can tell by driving it if its getting on the rev limiter but your kinda far away, shoot me your address in a email or PM I can send you my no rev CDI (Capacitor Discharge Ignition) to try...
PostPosted: Wed Oct 31, 2007 4:21 pm
will that CDI (Capacitor Discharge Ignition) have an option to buy on it? :-)
PostPosted: Wed Mar 20, 2013 12:45 pm
Old topic but I was wondering what the top speed of a pilot should be.I finally had an opportunity to test mine on a long stretch using gps speedometer app on an iphone.I have completely stock 89 pilot,my top speed was 51 mph,thought that was slower than I had hoped
