It is currently Sun May 18, 2025 6:11 pm
PostPosted: Wed Nov 26, 2008 8:45 pm
I rebuilt my starter with a new brush terminal, bearing, o rings a so on. Put every thing back together and it worked great but only for about 20 starts. Then stoped working. Took it back apart and found 2 of my brushes completly gone and the other 2 were about 1/3 there original size. They basicly turned into crumbs. My question is are there better rebuild kits than others. Or am I doing something wrong. Any help would be great. Thanks
PostPosted: Wed Nov 26, 2008 9:56 pm
I usually send my starter out for rebuild to ELWOOD at Stockers Starters-most old school stater rebuilder shops can rebuild it for you as well.Doesnt Piloodysseyperformance.com have rebuild kits?
What brand of rebuild kit did you buy?
PostPosted: Wed Nov 26, 2008 10:58 pm
Post pics of the surface area the brushes ride on.
PostPosted: Thu Nov 27, 2008 3:47 pm
Hoser here are some pics. of the armature. What do you think?
PostPosted: Thu Nov 27, 2008 3:52 pm
Mudbogger the rebuild kit I bought was off ebay from "starterman" I don't recall it having a name brand on it. It was a yellow blister pack with all the parts. Thanks guys for taking the time to help
PostPosted: Thu Nov 27, 2008 4:10 pm
That armature is WAY worn.
Those curves, high, low spots will catch the brushes and tear/rub them to pieces.
You may be able to turn or have it turned down to an even and smooth surface.
Check this page out and the links within it:
http://www.pilotodyssey.com/PO/view ... 50+starter
Lots of info there!
PostPosted: Thu Nov 27, 2008 7:33 pm
I can turn that in my lathe if you cant find someone to do it close to you.
Anybody know what the min OD is where the brushes ride?
PostPosted: Mon Dec 08, 2008 9:49 pm
Your armature came today I turned it down, it was in bad shape, you will notice some light scratches these are from me removing the burr that forms between the copper plates while machining, they wont hurt anything they look much better than they are thanks to the flash on the camera lol
The area where the brushes ride is now flat they brushes should last much longer..
Before and after pics.
PostPosted: Mon Dec 08, 2008 11:04 pm
that otta work much better
PostPosted: Tue Dec 09, 2008 7:44 pm
WOW that's looks great. I am so glad I ask for the help before I just went and put another set of brushes in and wasted money and time. This web site has been very helpful thanks for everyones help. And a special Thanks goes out to HOSER you are the man, I really appreciate you doing this for me. :-)
PostPosted: Tue Dec 09, 2008 8:00 pm
No problem glad I could help, great packing and I like how you setup the return shipping thing, it will be in the mail back to you tomorrow.
You aware of the oil in the starter problem for the 350?
http://www.pilotodyssey.com/350sb.htm
PostPosted: Tue Dec 09, 2008 11:11 pm
Yes I am aware but do not no what fix I should do seeing that there are different ways of doing it. Still doing my research, cause I don't really want to run my Engine low on oil just seems like a quick and easy fix for Honda.
