It is currently Mon May 19, 2025 12:07 am
 Post subject: 350 electrical ?
PostPosted: Fri Apr 16, 2010 2:09 am
Hello all, its been some time since ive been on the site, Hoser thanks for help for getting me on.. My rigs have been sitting for time.. 10 yrs plus.. Im starting to go through one.. throughin new battery, starter will not turn over..have power to starter button, when pushed. power to relay switch on positive side of battery. power to fuse both sides. so I call Hillside..igntion switch-DISCONTINUED, starter switch-DISCONTINUED, put in new starter relay & change switch.. still nothing. I need the help of Odyssey/Pilot fanatics to get this thing going, sorry to be long winded..
Odysseyfreek
PostPosted: Fri Apr 16, 2010 2:38 am
With the key on, do you have power to the starter itself when you push and hold the starter button?
PostPosted: Fri Apr 16, 2010 3:27 pm
Your starter could be in need of a rebuild.
Check what Randman asked.
PostPosted: Fri Apr 16, 2010 4:28 pm
I would tap on the starter while someone is pressing the starter button.
PostPosted: Sat Apr 17, 2010 2:18 am
with the key on, I do not have power to the starter post/terminal.... I will try to tap the starter w/ my son holding the starter button.. thanks for the reply's..
odysseyfreek
PostPosted: Sat Apr 17, 2010 12:19 pm
odysseyfreek
check all grounds per manual specs. did you try bridging the relay? i had the same problem, it was bad relay.
PostPosted: Sun Apr 18, 2010 2:26 pm
I would pull the cover off the steering wheel and then take apart the starter button and clean all the contacts well. Be sure not to lose the spring and I think there is a ball bearing that can get away from you. Since they have been sitting for a while i would take apart the starter relay and clean all the contacts. Good luck.
PostPosted: Sun Apr 18, 2010 3:05 pm
Check the wires coming off the starters solenoid, and the change switch wires as well, it may be the problem.You have no power at the starter,check it coming out of the soleniod going back to the change switch.
PostPosted: Thu Apr 22, 2010 2:37 am
I have bridged the relay, and the starter does turn over, I have checked the ground on the frame in front of motor (( Internal Combustion Engine ? )), I removed bolt cleaned area, Someone mentioned to take apart relay? isnt that a sealed unit, I did clean the post on it. . I wish I had more time to work on it, my time is very limited. thanks for the replys..
