It is currently Sun May 18, 2025 9:53 am
PostPosted: Thu Mar 21, 2013 10:56 pm
ok so i replaced stator, coil, CDI (Capacitor Discharge Ignition) and coil and all that, i also pulled all the grounds grinding them and re bolting them down with a new bolt. iv replaced every single electric part but the key its self... im lost. iv been threw the entire wiring harness too. all parts are new. i cant get spark at all. also theres no battery set up/wiring it was cut out and removed by previous owner!.. some one tell me how you can replace al lthe electic compents but still don't get spark! its a 85 fl350 a;; stock
PostPosted: Thu Mar 21, 2013 11:04 pm
Put the battery wiring back in. Also did you check the contacts in the run switch? Is your ignition switch plug connected tight? Have you ever had spark? Are you holding the plug to the head to check for spark? Did you check the resistance at the pick up inside the Engine? Is the pickup clean?
PostPosted: Thu Mar 21, 2013 11:07 pm
i cant put battery stuff back in cause i don't have it, i checked it all. its putting out. i also did the by pass of the gear switch and bypassed the on off switch... when i by pass on and off switch should it be grounded like the gear switch in back?
PostPosted: Thu Mar 21, 2013 11:08 pm
pick up n all that is brand spankin new.
PostPosted: Thu Mar 21, 2013 11:09 pm
when i picked it up it started n died. then wouldn't start. but he said when it ran it would like bog and when i tested it the stator was bad it wasn't putting out at all.
PostPosted: Thu Mar 21, 2013 11:11 pm
is there a way to just by pass the key and use a push button???
PostPosted: Thu Mar 21, 2013 11:12 pm
Is it all brand new honda or after market?
PostPosted: Thu Mar 21, 2013 11:13 pm
some came from honda some came from after market on the internet
PostPosted: Thu Mar 21, 2013 11:15 pm
i wonder if any one knows where i can get a oddy key ignition. its gota be it. iv been threw everything else
PostPosted: Thu Mar 21, 2013 11:19 pm
Why bypass? I would replace the harness with an uncut unbypassed harness with the battery stuff. Also test all the resistance of you electronic components per the manual to it can only be a few things.
Bad ground
bad CDI (Capacitor Discharge Ignition)
bad coil
bad run switch
bad stator
bad pick up
Bad harness.
It will be tedious but your gonna have to sit down with a tester and test each one.
PostPosted: Thu Mar 21, 2013 11:21 pm
I JUST SAID I REPLACED ALL THAT STUFF YOU JTS LISTED AND BEEN THREW THE ENTIRRE HARNESS
I thought you were being sarcastic. When you said you havent replaced the key. So your ignition switch hasnt been changed? that's next on the list.
PostPosted: Thu Mar 21, 2013 11:25 pm
I understand but just because you replaced it doesnt mean it works. You obviously still have a problem and with putting all new stuff in something STILL doesnt work so you will have to check all the new stuff to see which part is defective. I have had a brand new coil not work before. And ended up trying parts off of a running machine to finnally track the problem down to the very part I bought new.
