It is currently Fri May 16, 2025 12:16 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 18, 2011 2:14 pm
Looks like I will have to order a clutch from Neil. I have searched from A-Z over the internet with little to no success.
PostPosted: Fri Feb 18, 2011 2:47 pm
I have a 162 with a dial a jet... try 167 or 165
1frc wrote:
Turbotexas wrote:
give 1frc first dibs on the 39mm
Im not sure if Im going to like the mikuni I have???
I have extra rear shocks in good shape if that interest you???
Why thank you kind sir. I am waiting on some pics, then I will also need to pull the other 39mm of the other pilot to match the jetting.
"H" - I have heard on multiple occassions that you have a pretty good idea of wht the usually settup in on the 39mm. We are about 500-700 above sea level out here in Texas.
PostPosted: Fri Feb 18, 2011 2:48 pm
I am currently running a 172 and may need a tad bit more.
PostPosted: Fri Feb 18, 2011 2:50 pm
stock motor (( Internal Combustion Engine ? ))???
PostPosted: Fri Feb 18, 2011 3:29 pm
Turbotexas wrote:
You should know me better than that by now.... :-)
PostPosted: Fri Feb 18, 2011 3:59 pm
Here are a couple pictures for you
http://i285.photobucket.com/albums/ll57 ... bRight.jpg
http://s285.photobucket.com/albums/ll57 ... rbLeft.jpg
http://i285.photobucket.com/albums/ll57 ... rbBell.jpg
I ran these on trx250r race engines which is why you see the little rash on the bowl. But otherwise everything is in great shape.
PostPosted: Sun Feb 27, 2011 12:56 am
Is $150 the going rate for the 39 pwk in good shape also are they different jets than the factoy carb uses
