It is currently Sat May 17, 2025 1:48 am
 Post subject: WTB Fl250 wiring harness
PostPosted: Sat Jun 02, 2012 9:23 am
I'm looking for a wiring harness for my 250, or just the plug that goes into the CDI (Capacitor Discharge Ignition).
Thanks,Randy
PostPosted: Sat Jun 02, 2012 3:22 pm
The ATC110 with CDI (Capacitor Discharge Ignition) has the same plug as the FL250. Even the same color wires. I was able to Ebay one off a ATC110 much cheaper than the ones listed for FL250's.
Just make sure it's a CDI (Capacitor Discharge Ignition) ATC110 and not the early points models.
PostPosted: Sat Jun 02, 2012 3:33 pm
I just looked in my parts pile. I do have one. It's all hacked up but the CDI (Capacitor Discharge Ignition) plug and coil wires is on it. It came off a fl250 that PO wired a Goki starter in. It's a mess for sure but it has what you need. Also has the stator wires but one connector is cut off.
$10 plus $6 USPS flate rate shipping box.
If you want it I will PM you my Paypal info.
Will take pics later when I get back out to shop. Do you have the coil?
Look here
viewtopic.php?f=40&t=9953" .".." .".." ."..
I also have stator and magneto but has slight wear or slight grind marks. I would have to take macro pics and consider condition. BAsicaly whwn I took it out there were shavings all over. Not bad but yes there were shavings.
PostPosted: Sat Jun 02, 2012 5:10 pm
pics. not sure whats on it for it's a bird nest for sure. The CDI (Capacitor Discharge Ignition) plug is on it though.
I need all the goki stuff on this harness. So lets just say it's the CDI (Capacitor Discharge Ignition) plug only as of right now. I am sure there is more but heading to wedding right now.
Like I said it's a huge birds nest hack job for sure. LOL
