It is currently Mon May 19, 2025 11:47 am
PostPosted: Sat Oct 12, 2013 3:58 am
Anyone got the following for a pilot?
Reverse selector cable
Front brake hoses
Aftermarket exhaust
Aftermarket clutch, powerblock etc?
Please PM or email shaunstewart9@hotmail.co.uk
PostPosted: Sun Oct 13, 2013 9:30 am
How is your old cable you remove it and clean it out, force a mild solvent through the cable then blow out with compressed air, dirt usually stiffens them up, also take the side cover off the shifter and clean it out where the cables go in that makes it shift hard or not at all.
I usually flush and clean cables with silicone spray or something like WD-40
90% of the "bad" cables I have encountered in my life time are actually just dirty so clean and lube good to go the only bad cables I have found are High load high use cables lik clutch cables on bikes and quads they usually meet a early death because of dirt, ever notice a street bike clutch cable will last 70k miles and 25 years but the same cable in the dirt is dead in 3-4 years :shock:
Worth a try before you pay 50 bux for a 12.00 cable
PostPosted: Sun Oct 13, 2013 10:36 am
$50.00 - I wish I could find one for that. More like $100.00.
PostPosted: Sun Oct 13, 2013 11:15 am
try pilotpete1, if he can't help you let me know
PostPosted: Sun Oct 13, 2013 8:46 pm
I have purchased from both those sellers with excellent transactions! Recommend them highly to you for parts buying.
PostPosted: Mon Oct 14, 2013 1:37 am
Thanks for the replies, the cable is snapped, i tried Pete, he doesnt have one.
PostPosted: Mon Oct 14, 2013 2:04 am
you need 1 cable or both?
PostPosted: Mon Oct 14, 2013 3:13 am
You can have them made new for less than 100 bux?
http://www.motionpro.com/motorcycle/custom/
PostPosted: Mon Oct 14, 2013 4:27 am
Jus the reverse one.
Thanks hoser, ill check it out
PostPosted: Mon Oct 14, 2013 9:44 am
Your in the UK ?
I bet you have companies over their that can make custom cables also, probably cheaper, ask around take the old one with you.
Better yet
https://www.google.com/search?q=custom+ ... =firefox-a
PostPosted: Fri Oct 25, 2013 12:56 pm
Thanks for the help hoser!
Anyone got anything else? Pipe and clutch in particular.
Shaun
