It is currently Sat May 17, 2025 1:41 am
 Post subject: FL400R cylinder
PostPosted: Fri Jun 20, 2014 7:54 am
What are these selling for? I have one on 84mm bore.
 Post subject: Re: FL400R cylinder
PostPosted: Fri Jun 20, 2014 8:51 am
What piston were you running in it?
Do you have the matching head and any spacer plate it might have been used?
PostPosted: Fri Jun 20, 2014 9:55 am
Hoser, I believe this is a modified cylinder for a 250r bottom end based on his last post.
There was a complete setup for sale I had just seen that was using an 84mm piston from a Polaris 400 quad. Wiseco number 675M08400
PostPosted: Fri Jun 20, 2014 10:19 am
The Polaris quad uses a 18mm wrist pin so that piston will not work in the Pilot unless you find a rod that will fit and swap it out also, might as well have custom pistons made at that point. https://www.wiseco.com/ProductDetail.as ... =&ModelID=
PostPosted: Fri Jun 20, 2014 8:17 pm
Yeah, I seriously almost jumped on that. I figured it would be too much time trying to get it up and running. but it sure would be fun after it was completed. I tried to add a photo but once again back in that whole problem of figuring it out. It says The extension is not allowed.
PostPosted: Fri Jun 20, 2014 10:01 pm
Yes, it is set up for a trx bottom end, have the head also
PostPosted: Fri Jun 20, 2014 10:46 pm
Right on someone here from the board owns it. yeah I thought about it over and over and im thinkin man i got 30 other projects this is last thing i need. Im sure it will be super sweet once its done. has anyone of the 250r forum picked it up yet?
PostPosted: Fri Jun 20, 2014 11:07 pm
Nope, supposed this combo makes 75+ hp....on a quad = scary!
PostPosted: Fri Jun 20, 2014 11:47 pm
=FUN :)
PostPosted: Sat Jun 21, 2014 12:01 am
Are you selling the cases with it?
PostPosted: Sat Jun 21, 2014 8:58 am
What happen to the rest of it like the pipe, what are the crankshaft requirements to make it work on the TRX.
PostPosted: Sat Jun 21, 2014 1:02 pm
Everything pictured along with a brand new piston. $650 + shipping and pp fees
PostPosted: Sun Jun 22, 2014 6:54 pm
Hoser, this motor (( Internal Combustion Engine ? )) has never made it that far, only had the case work done by Packard
PostPosted: Mon Jun 23, 2014 3:16 am
so your getting the two lower cases and the cylinder with a new piston correct? Is there any repairs around the case saver bolts or the drain plug.
PostPosted: Mon Jun 23, 2014 7:02 am
Correct - no repairs to case saver bolts or drain bolt!
