It is currently Fri May 16, 2025 12:30 am
PostPosted: Sun Jul 12, 2015 3:08 pm
NOTE" I have an Ebay sale pending, the buyer sent me a deposit so I am waiting for the remainder of payment. Ill keep this post updated as the transaction moves along.
Im selling my 89 Pilot in excellent condition. It has the CR500 conversion modified FL400 Engine that was rebuilt by Hoser who is well known in the Pilot Odyssey community for his quality top notch Pilot and Odyssey Engine rebuilds (top end and bottom end rebuilt), and crank was rebuilt by Speedchaser, I have put about 15 hours on the rebuild. The CR500 Engine conversion was performed by ATV Racing in Arizona, the CR500 Engine modification consists of a CR500 cylinder mounted to the FL400 bottom end. So you get a 500cc Engine with gobs of torque instead of the stock 400cc. The Engine rebuild consisted of all new crank bearings (Japan C3),all new Honda seals, gaskets, Wiseco piston/rings, Honda mechanical seal, rebuilt crank with new rod and both big and little end bearings, new cool head, new hoses, new V Force reeds petals, static compression is 160, Compression Ratio is near stock, Im sure Im leaving some stuff out. During the rebuild I decided to install a modified Keihin PWK 39 Stryker carburetor and custom intake built by Ron at Pulse Engeneering, the jetting can be done on the fly with a flat head screwdriver just like the dial-a-jet with this carburetor, I have the cut sheets which can explain all this but it is jetted properly at this time, right now a little on the rich side, you don't have to mess with it unless you like to "tweak" stuff. Also new is the Comet 102c driven clutch with the Thundershift kit, this clutch has been "set up" with the proper spring and weights to run 7000 rpm for maximum torque from 0 to top speed. Among other goodies is of course the ATV Racing Long Travel modification performed to the front and rear suspension fitted with AXIS shocks with reservoirs which gives you more travel over stock and a wider rear tire stance since axles have been lengthened a couple inches, CR500 ceramic coated pipe, digatron instrument panel displays RPM Coolant Temp,EGT and speed, stainless brake lines, front and rear bumper, full skid plate, heat shield, beard seat, Axis shocks with reservoirs, rear suspension has been tweaked from ATV Racing's stiff "set up" to a more comfortable ride, Skat Trak Hauler paddle rear tires douglas rims, the front rims are very close to the stock offset, LED headlights, aux radiator, prefilter, new Honda OEM coolant overflow tank, powdercoated frame with no rust at all, ATV Racings chromoly roll cage. Lots of maintanance has gone into this Pilot including lubricating and proper torqued bolts to Honda manual spec, all steering wheel switch contacts were cleaned and lubed with dielectric grease, silencer repacked, driven clutch serviced, CV boots replaced with Honda OEM and bearings repacked as needed. All modifications or upgrades were meticulously installed. Im sure Im leaving somestuff out look at the pics, this Pilot is turn key, get in it and ride! I hate to sell her but my wife and I decided a two seat dune buggy is going to fit our needs better at this time. This is an extremely clean Pilot, Ill ship it anywhere but you will have to set up with the shipping carrier, I have used uship and it was a painless process. Im wanting $8000 firm. PM me here or post . thanks
NOTE: Search Ebay for " 1989 Long Travel Honda Pilot FL400 " to get better quality pics
PostPosted: Sun Jul 12, 2015 3:19 pm
more pics
PostPosted: Sun Jul 12, 2015 3:42 pm
pics
PostPosted: Sun Jul 12, 2015 4:26 pm
WOW!
She sure is pretty:()
PostPosted: Sun Jul 12, 2015 11:05 pm
Guess it sold quick. Ebay link says no longer there.
PostPosted: Sun Jul 12, 2015 11:45 pm
No it didnt sell, Ill edit the ad with sold when it sells. I cant get the darn Ebay link to work, you can search
" 1989 Long Travel Honda Pilot FL400 " at Ebay to find it.
thanks for the heads up Duneit
PostPosted: Mon Jul 13, 2015 9:56 am
Looks like it's not on eBay anymore. I can't find it.
Very nice pilot BTW.
PostPosted: Mon Jul 13, 2015 6:38 pm
PostPosted: Wed Jul 15, 2015 10:54 am
Dam Stix you sold it to cheap. Some one got a good buy. Sorry to see it go. Still got the other springs?
PostPosted: Wed Jul 15, 2015 12:03 pm
Yes I could have gotten few bux more, well what the heck I got lots of good use with it. I have the springs.
PostPosted: Wed Jul 15, 2015 3:30 pm
If you don't mind me asking, what's the hose for that's going through the top of the intake manifold?
PostPosted: Wed Jul 15, 2015 3:55 pm
Good eye. It's the pulse induction intake. look up pulse engineering, Ron built that Intake and has it tuned to the cr500.
PostPosted: Wed Jul 15, 2015 4:03 pm
Does he have a website? I found his products on different forums but can't seem to find a website if any.
PostPosted: Wed Jul 15, 2015 8:28 pm
I don't know if hes has a website but he sells on Ebay
http://www.ebay.com/itm/Pulse-Injected- ... 58&vxp=mtr
PostPosted: Wed Jul 15, 2015 9:25 pm
Interesting what kind of power increase did you experience after installation? Do you recommend this set up to others?
PostPosted: Wed Jul 15, 2015 10:18 pm
I guess it depends on your expectations as to whether I would recommend. It did exactly what Ron said it would do for me. His dealings is with motorcycles with manual transmissions. I bought it to take care of a jetting problem I had, I can expound if needed. Well it fixed all my jetting issues, the Engine starts MUCH easier, first 2 or three revolutions of crank and it fires up, and idles like a 4 stroke, meaning a smoother idle. As for power I couldnt tell a difference but Im not very good at "feeling" horsepower, unless its substantial. Also no more jetting to different ambient temps or altitudes. Once you get your baseline jetting done, jetting can be done on the fly by turning the idle/air screw, no it doesnt change your idle air mixture so to speak, I don't know exactly "how" it works but the screw will let you jet your main for different ambient temps and altitudes, now Im guessing it also jets your idle and mid. Hope that helps
PostPosted: Thu Jul 16, 2015 12:13 am
Sorry to hijack your thread but did going to an air striker carb allow you to change jetting by a screwdriver or was using the pulse intake allow you to do that?
PostPosted: Thu Jul 16, 2015 12:18 am
Never mind. You answered my previous question. Did the intake fit well with the 500 jug, carb and elbow boot? I ask because I'm about to start a 500 conversion build.
PostPosted: Mon Jul 20, 2015 10:28 pm
I couldnt find the EDIT button,
Pilot is SOLD, and on its way to West Virginia, I told the new owner about the forum, hes been lurking here for a while.
PostPosted: Tue Jul 21, 2015 7:40 am
Beautiful machine (shiny)
