jknarfal wrote:
DMoneyAllstar wrote:
Does anyone have an Oddy or Pilot with an RPM or Team box in it? I can't recall if I've seen one nor can I find one. Plenty of other non-Honda ones with it.
here's one
viewtopic.php?t=3835Thanks, that's also the only one I can find. Ain't pretty, but it gits-er-dun. There are plenty of bigger buggies & rails using spools or the big Jeffco/Toms boxes, but not easy to find project details on the RPM.
Just wondering what the cost/hassle delta would be between making custom axles for a stock Oddy 350 box versus finding a decent FNR. The custom-axle thing is something I'd like to shy away from. Its been the stall point on my LT project (besides having no effing free time).
Seeing an RPM sell for $1G has put me into "
ponder mode". Hey at least I'm on my lunch hour!
That RPM that sold was setup for 930's. Is that kinda' overkill for a sled
Engine conversion on a single seater? Granted the Rotax 670's are rated at something like 120-140hp. And let's totally ignore the power versus roll-cage safety stuff for discussion purposes.
I saw that Protodie makes/sells Rhino 660 axles with 930 inners for $150. Are these just Rhino-fitting outers with 930-matched inners? I assume you'd have to use the Rhino carriers (not nearly as available as the RZR stuff), or otherwise use the stuff P-Die is selling/making. Does anyone else make 930 parts that can swap in/out of UTVs?
Otherwise you'd need to come up with something more custom, which isn't nearly as simple as using a RZR XP900 carrier, hub, & brakes. The RPM trans with the RZR XP carrier would be about as simple & drop-in as you can get (radius arms would be simple). Should be plenty tough for the 100-150hp single seater with droves of economical spare parts support.
