It is currently Wed May 14, 2025 1:27 am
 Post subject: gone
PostPosted: Tue Apr 14, 2009 12:33 am
selling off and going different route.
PostPosted: Tue Apr 14, 2009 12:36 am
HEHE works shocks , comet clutch, aluminum tank, and aluminum wheels would be nice too just in case someone had some laying around.
PostPosted: Tue Apr 14, 2009 7:26 pm
kingjason wrote:
Carb, Cylinder complete with reeds, exhaust and bolts,head, CDI (Capacitor Discharge Ignition),Coil,Rectifier assembly, ign w/key, rubber motor (( Internal Combustion Engine ? )) mounts and bolts, top section of cage not bent. I swear some of the dealers on Ebay are running up the prices. PM me with what you got. Trying to put this thing back together reasonably.
ok, I have parts that may be ok for you, need some clarification please-
Carb-stock 1 I assume-I can't guarantee a carb as they do wear over time but I'll look for you-The cylinder do you need piston with it, also ok if it needs honing?Head shaved or unshaved as I have both-exhaust flange I assume you are referring too right? stock reed cage-np-reeds for 20-30 bucks buy them new-silly!!!-top cage condition of paint?,appearance?,also shipping alone for that is gonna high as it is heavy and bulky.What are you looking to spend as I have seen prices pretty low in recent weeks for all 350 items, hell I picked up a trans for $172.00 shipped off Ebay.CDI (Capacitor Discharge Ignition) I do not have-coil-rectifier-np,ignitions I sell as matching set with gas caps-do not know if that's good for you-rubber motor (( Internal Combustion Engine ? )) mounts you want to buy them used?motor (( Internal Combustion Engine ? )) mount bolts I have no trans bolts?
PostPosted: Tue Apr 14, 2009 9:59 pm
Yeah I watched that tranny go cheap but every time I bid on that whole CDI (Capacitor Discharge Ignition) it just kept jumping. I will PM you.
