kingjason wrote:
Carb, Cylinder complete with reeds, exhaust and bolts,head,
CDI (Capacitor Discharge Ignition),Coil,Rectifier assembly, ign w/key, rubber
motor ((
Internal Combustion Engine ? )) mounts and bolts, top section of cage not bent. I swear some of the dealers on Ebay are running up the prices. PM me with what you got. Trying to put this thing back together reasonably.
ok, I have parts that may be ok for you, need some clarification please-
Carb-stock 1 I assume-I can't guarantee a carb as they do wear over time but I'll look for you-The cylinder do you need piston with it, also ok if it needs honing?Head shaved or unshaved as I have both-exhaust flange I assume you are referring too right? stock reed cage-np-reeds for 20-30 bucks buy them new-silly!!!-top cage condition of paint?,appearance?,also shipping alone for that is gonna high as it is heavy and bulky.What are you looking to spend as I have seen prices pretty low in recent weeks for all 350 items, hell I picked up a trans for $172.00 shipped off Ebay.CDI (Capacitor Discharge Ignition) I do not have-coil-rectifier-np,ignitions I sell as matching set with gas caps-do not know if that's good for you-rubber motor (( Internal Combustion Engine ? )) mounts you want to buy them used?motor (( Internal Combustion Engine ? )) mount bolts I have no trans bolts?
