It is currently Sat May 17, 2025 3:59 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 20, 2013 3:00 pm
Copper bars were bolted to the cases to back up the edge where its welded.
PostPosted: Wed Feb 20, 2013 3:01 pm
Small groove was ground into the case so you can follow the crack when welding.
Crack welded up
Hole welded up
outside
PostPosted: Wed Feb 20, 2013 3:03 pm
All OEM bearings, seals, gaskets will be used. :-)
PostPosted: Fri Feb 22, 2013 1:13 am
Thank you very much for your hard work, I can not tell you how much it is appreciated.
Make her strong, she is kind of like David against Goliath. You know 400cc against 900cc.
I actually got my axles out, yee ha. I should have the trans. prepped and installed this weekend I hope.
PostPosted: Fri Feb 22, 2013 11:18 am
Damn nice weld job there, sir! :-)
PostPosted: Fri Feb 22, 2013 5:40 pm
I don't think its welded in that pic? Just the piece sitting in place before welding.
Nice work Mr.H
PostPosted: Fri Feb 22, 2013 11:44 pm
Nice work Mr.H
dosent look like it
PostPosted: Mon Mar 18, 2013 12:36 pm
More pictures, the old crank see the parts of the old piston in the oil groove of the big end bearing, the crank is still good but needs a rod kit installed, might be able to reuse the old rod just take apart, use new pin and bearing remove piston parts?
PostPosted: Mon Mar 18, 2013 12:37 pm
New balancer was installed.
PostPosted: Mon Mar 18, 2013 12:56 pm
Perhaps I just missed it, and as much as I love new parts, Why did you have to install a new balancer? What was wrong with the old one?
PostPosted: Mon Mar 18, 2013 1:13 pm
Old balancer was still good Steve wanted a new one installed, old one will be kept for future spare.
PostPosted: Sun Mar 02, 2014 7:33 pm
Glad to see some headway being made Steve. You should be ready for Spring riding??
Registered users: Baidu [Spider], Becerra, c5racer, Google [Bot], Lanix, Rppjr, socalgii
