It is currently Mon May 19, 2025 8:42 pm
 Post subject: fl400 driven change out
PostPosted: Wed Nov 30, 2005 9:37 pm
hoser, thanks for reply on the pipe. I did notice you run a different driven on you new set up. Are you using an adjustable one on your pilot gear case. if so did you use a spline adapter or replace the shaft. I'm to the piont on mine that it time to work in driven dept. I have put out fellers to CDI (Capacitor Discharge Ignition) manf. on an programable ign with an adjustable revlimiter and tach output for the pilots but its slow going. there telling me that it will take at least 1000 order for them to even consider. How ever they did say it should be able to be done. If you can explain to how to post pictures I will give a try tech stuff on the net that not my thing. I thow away most of my bad parts put keep the one that interest me.
PostPosted: Wed Nov 30, 2005 10:17 pm
posting pics is easy.
Do you have a digital camera ? and a folder that you have pics stored into on your computer ?
Go to post a reply as usual- post your reply
when you want to add a picture click the browse button below
it will bring up the files in your computer-choose the file you have your stored pics in and choose the picture you want to post-
If you want to put a comment on the picture you have choosen then write it in the comment box below.
After finishing your choice of pic and comment click the add attachment -it will take a second and your pic will be added to the post.
you will have to do this for each picture you want to add-keep in mind you do not have to add a comment if you don't want to.
So in short you want to - write reply (if any)-hit browse and choose picture-hit add attachment-
after you get all the pics added Then click Submit
You can put on up to 8 pics per post
Try it you cant hurt anything :-)
When you go to choose your pictures out of your computer file you can either double click the pic or hit open and it will send the pic to the board automatically,then hit add attachment and go onto the next pic.
each time you add a picture to the post it will show and tell you what pics you have added so far.
PostPosted: Wed Nov 30, 2005 10:35 pm
I changed the input shaft in the trans (see pic) to a shaft that Dan Roberto made for the Pilots years
ago you would have to call him to see if he still has any left. I then I installed a comet 90D
driven clutch that was setup for the FL350, I am thinking about trying a 790 driven this
guy has them http://home.mindspring.com/~royco/
To post pics in this thread you can click reply and type in your reply as normal then
down towards the bottom click on the "Browse" button a box will open and you
navigate on your computer where the picture is you want to attach then click
add attachment you can add like 8 pictures if you want to add text by the picture
you can type the text in the box next to the "Add Attachment" button, once your
all done adding pictures just click the "Submit" button as you normally do to reply
to a post.
You can add pictures in a new post you start the same way.
Play with it its easier than it sounds once you do it their is nothing to it.
File comment: Dan Roberto Pilot input shaft.
