It is currently Wed May 14, 2025 8:08 pm
 Post subject: Primary Clutch
PostPosted: Wed Apr 03, 2013 7:12 pm
I , am looking to replace the clutch on my FL350r and I found a 94C Comet clutch on Ebay, are these better than the stock clutch or would I come out better trying to find the parts to rebuild mine? My clutch is working but shakes pretty bad.Can this be fixed or is it worth it? Any help would be helpful. Thanks Billy
 Post subject: Re: Primary Clutch
PostPosted: Wed Apr 03, 2013 10:38 pm
The 94c is a great clutch. Better then stock and worth getting
PostPosted: Thu Apr 04, 2013 8:39 am
Thanks I have a bid on it. Can the clutch be changed with the Engine installed or will I have to pull it to get the clutch changed? Thanks Billy
PostPosted: Thu Apr 04, 2013 1:41 pm
no you don not have to pull the Engine off but most times the stock clutch is a bitch to get off because it hasnt been off in years
Youll need to buy one of these if you don't have one
http://www.ebay.com/itm/HONDA-FL350-ODY ... d2&vxp=mtr
And if your 94c clutch doesnt come with one youll need to purchase one for it also if you ever want to take it off
PostPosted: Thu Apr 04, 2013 1:45 pm
Why buy that at that rip off price. make your own.
PostPosted: Thu Apr 04, 2013 1:50 pm
I had mine off about 6 months ago when I rebuilt the top end. So maybe it will come off kinda easy..
PostPosted: Thu Apr 04, 2013 1:51 pm
well some people arent equiped to do so,if you can make one cheaper than you should make some and sell them :-)
And Im not trying to be a smartass so don't take it like that
thanks
PostPosted: Thu Apr 04, 2013 1:58 pm
You can be a smart ass - won't hurt my feelings. I just hate to see people get ripped off.
PostPosted: Thu Apr 04, 2013 2:04 pm
Yeah i don't either
Since he wanted to know if the Engine had to be pulled to get off clutch I figured he hadnt done it before and he would need the proper tools to do it
PostPosted: Thu Apr 04, 2013 3:39 pm
Bunch of clutch puller discussion here use the power of the search :-)
http://www.google.com/search?q=clutch+p ... dyssey.com
Once you know the bolt size that is 1/2 the problem, think I paid like 2 bux a bolt for the 3/4 bolts at the local IH implement probably cheaper else where I bought mine while I was their getting other tractor parts.
Then I just use one of my many punches for the pin to push with I measure the total depth of the hole then allow at least 1" thread engagement then cut the punch off at the length I need for the push pin, the punch will not bend like more store bought pullers push pin does insert the small end first so its pushing up against the end of the hole Honda drilled in the crankshaft
Link for clutch holder
http://www.google.com/search?q=clutch+h ... dyssey.com
