Lonerider wrote:
I have not owned a 350 for a while, but shouldn't he get the starter fixed first, in order to get a good compression reading? Thought the pull start would not provide a correct reading......
Yep, for good comp test results the e-starter is the best.
But I recommend for "Kiwi" a heavy dose of "
DROP EVERYTHING & LEARN THE BASICS OF 2-STROKES" right away before the knowledge gap starts kicking him in the wallet!!
Few basics here before you start costing yourself $100's of issues...
1. 2-strokes use a mix of fuel and 2-stroke oil, generally a 32:1 gas:oil mix. Some vehicles (like the FL350) require pre-mix (tank holds gas/oil mix). While other vehicles like snowmobiles have a separate oil reservoir for oil and pump/inject it into the Engine. If you don't know what's in the tank and/or it might be wrong, DRAIN IT and put in FRESH pre-mix with the correct ratio. Get good quality 2-stroke oil. Good stuff costs ~$40/gallon, but remember that at 32:1 ratio, you're only using 4-oz of oil per 1-gal fuel. Also, today's ethanol blended fuels contain ethanol (duh). This stuff turns into a gummy varnish after sitting untouched for as little as 1-month.
2. Heat is the 2-stroke's worst enemy. Lean conditions is the easiest way to get too much heat. And air leaks are the easiest way to get too lean. Runner up would be incorrect carb jetting. Learn how to do a LEAKDOWN TEST on your
Engine before you try to start it.
3. Even if you've got air, fuel, and spark...you still need COMPRESSION in your Engine. Like someone mentioned, get a compression gage from the parts store or Harbor Freight. If you don't have comp, you're wasting your time, patience and energy trying to start this sucker.
4. Pull your carb apart and check the main jet # and pilot jet #. Verify they're right for your modifications and altitude.
5. Check your wiring, especially the functionality of your kill switch. If you get this Engine started and it starts to rev out of control (aka: lean condition death rev), you want to be able to kill this Engine before its too late.
6. Download the manual & read it (ignore the recommended 20:1 fuel/oil ratio), read through this site, and learn as much as you can.
7. **STOP USING STARTING FLUID**STOP USING STARTING FLUID**STOP USING STARTING FLUID**
8. Most importantly, don't get frustrated. So its your first 2-stroke - who cares? Everyone starts somewhere!
Edit...one more!
9. Come to terms with the fact that owning a 2-stroke requires some maintenance & money.
