It is currently Sun May 18, 2025 3:12 pm
PostPosted: Fri Sep 13, 2013 9:36 pm
After this Pilot air box lid was generously donated by Mudbogger. I installed 2 Thunder TPI valves. These will allow me to go rich or lean when the ambient air temp changes. The lid was sunbeaten so I hit it with some 100 grit sandpaper, then cleaned with plastic prep, then rattled canned with some close to Honda red paint for plastic. Both valves will open and close in increments and are supposed to stay in that position when riding. Here is a link to some close up pics of the TPI valves.
viewtopic.php?f=4&t=12669
PostPosted: Fri Sep 13, 2013 9:37 pm
last pic
PostPosted: Fri Sep 13, 2013 11:28 pm
Nice work Marc,those look nice,great job
I hope those work out well for you at LS
PostPosted: Sat Sep 14, 2013 12:24 am
Looks good buddy
PostPosted: Sat Sep 14, 2013 1:04 am
Its gets chilly at night and in the mornings then heats up during the day at Little Sahara in spring and fall, so this should make tuning a little easier.
PostPosted: Sat Sep 14, 2013 5:27 am
I also have these installed on my turbo pilot and they work very well with a dial a jet
glad I could help you with the airbox lead very nice work
PostPosted: Sat Sep 14, 2013 8:19 am
Never thought of hatches before, came out real slick! Nice work.
PostPosted: Sat Sep 14, 2013 9:26 am
Looks good my only concern is they are going to fill up with dirt or when you go to the dunes sand then as you drive and bounce its going to fall into the air box onto your filter inside.
What you going to do when it pours rain or you come over a blind hill and land into a huge mud hole?
Doing the dual filter mod then installing the dampers after the filters with the dampers mounted vertically would avoid most problems?
We install these in dust collector systems all the time I have even made some from scratch out of stainless steel for chemical plants
https://www.google.com/search?q=blast+g ... =firefox-a
Half blast gates would be easy to fab to install behind the prefilters at the upper prefilter bracket you just cut a slit in the pipe then pop rivet it on
http://www.airhand.com/products.aspx?Ca ... ategoryID=
PostPosted: Sat Sep 14, 2013 1:13 pm
https://www.google.com/search?q=blast+g ... =firefox-a" .".." .".." ."..
http://www.airhand.com/products.aspx?Ca ... ategoryID=" .".." .".." ."..
Looks like the blast gates come in different sizes. I gonna look into some kind of hood to cover from the sand and rain. Maybe something like this?? http://www.lowes.com/pd_317909-85334-VTL0016_0__ .
PostPosted: Sat Sep 14, 2013 1:39 pm
This one made me laugh. DBloudHarley and I were at LS a few weeks ago, We were night driving and i came over a tall dune only to find a huge pond just on the other side of the dune, I cranked the wheels but not enogh time, cant back up a 20 foot 45 degree sand hill. I ended up driving through, wasn't that deep, maybe a foot.
PostPosted: Tue Nov 05, 2013 9:14 pm
more modifications to my air box lid after some sand was resting on the outerware that is mounted between the lid and box. Im still able to open and close one of the vents without removing the piece of outerware attached to the 45 degree cover piece, i can access the other vent by removing the piece of outerware that I attached with some black trim.
PostPosted: Sat Mar 22, 2014 10:13 pm
Hey Stixy,hope TT don't find out what you've done with his chick magnet hat. :shock:
He gonna dance with you mate! :-)
PostPosted: Sun Mar 23, 2014 1:42 am
PostPosted: Sun Mar 23, 2014 7:23 am
That ain't nuthin' Stixy!
Turbo was brought up on that stuff as a babe,nipple fed in fact....................by his Pappi! :shock: Image
PostPosted: Sun Mar 23, 2014 12:16 pm
Lid installed
