It is currently Mon May 19, 2025 5:16 am
PostPosted: Sun Mar 18, 2012 10:37 am
91202-VM0-003 OIL SEAL, 25X40X8
Anybody find a replacement?
PRO-X has these 25x40x8 part number 41.2-25098
PostPosted: Tue May 01, 2012 12:50 pm
This is still available at Honda dealers.
PostPosted: Mon Oct 21, 2013 11:43 am
Confirmed PRODUCT OBSOLETE now
http://www.partzilla.com/parts/detail/honda/HP-91202-VM0-003.html
OIL SEAL (25X40X8) (Honda Motorcycle Code 1787126)
Going to order this seal and see what it looks like
http://www.partzilla.com/parts/detail/kawasaki/KP-92049-Y010.html
PostPosted: Mon Oct 21, 2013 3:44 pm
ODDATV1 has the seal. Joe had a large run of them made.
Please post pictures of the seal when you get it! If its the same seal, for 1.81 each, I'm stocking up!
PostPosted: Fri Nov 29, 2013 9:31 pm
Got this seal in today I see no reason not to use it on the FL350 looks like any other seal, the name on the seal is piantk it also said 6050 and TC 25 40 8
Price is right
Will try to get some quality detail pics and will update this post.
PostPosted: Tue Sep 22, 2015 12:51 pm
Price is right
Whatever happened with this. Did the Kawi seal work out?
PostPosted: Tue Sep 22, 2015 5:28 pm
Price is right
I have never installed this seal its still in my parts box I do not see why it can not be used, make sure to lube the seal where it rides on the shaft with grease before installing as with any other seal then confirm it seals by pressure testing.
PostPosted: Tue Sep 22, 2015 6:33 pm
just ordered one. I will let you know how it works out.
Chris
PostPosted: Sat Oct 17, 2015 2:17 pm
Chris
I just picked up 3..... so how did you make out?
