It is currently Wed May 14, 2025 10:03 am
Post new topic Reply to topic  [ 105 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Mon Oct 28, 2013 1:39 am
I am trying to make a water cooled head out of my air cooled.
The problem is that the head seems to made out of pig iron of some sort.
I have a brand new miller welder and spool gun for running aluminum wire.
I am running .030 wire 4043 aluminum with 100% argon at 40gph.
When I tried welding on one of the fins I cut off as a test, the weld was full of porosity.
When I welded on a piece of good aluminum plate the welds were great.
Everything was cleaned with a new stainless brush and acetone.
(yes I did try it on one of the cyl fins before I cut the fins off the head and it worked, but
I confess I only made a very small tack weld on the cyl fin).
Anybody got any suggestions?? Has anyone here tried it??
Thanks in advance for any suggestions or info.
PostPosted: Mon Oct 28, 2013 1:54 am
Welding cast aluminum is a pain in the arse
All I can say is it must be clean clean clean
Sand blast the head till it's nice an clean with new clean glass beads if ya can
Use a SS brush to clean it afterwards use some acetone or carb cleanerfor the final clean not brake cleaner
Tig welding is what you will need
Mig welding alumium doesn't work at all I've tried plenty of times with cast that's why I got a tig welder
Pre heating cast aluminum works best
With a torch or a oven (oven works best) forget what you preheat it to I'll have to look it up
What is your current welder ?
What did you cut the fins off with?
I had the same idea about making a air to water cooled head but ran out of time it looks verry hashey not finished with it got most of the fins cut off that's about it tried to weld on it with a spool gun but that diddnt help at the time this was about 8-10 months ago?
Would love to see your finished product
PostPosted: Mon Oct 28, 2013 2:22 am
Damn. I have a tig torch but not the high frequency welding unit to go with it.
I have many welders: 160amp ac/dc, flux core wire feed, brand new mig wire/gas, and a brand
new millermatic 180 with a spool gun for aluminum.
I guess you seem to be saying it's not clean enough so I will try to bead blast it. (Don't have one yet).
I cut the fins off with a zip cut wheel and a hammer (i'm a bit of a cave man sometimes LOL It's the
sawmill millwright in me).
PostPosted: Mon Oct 28, 2013 2:29 am
what brand and model of tig welder
PostPosted: Mon Oct 28, 2013 2:53 am
I just have the torch not the welder it hooks to.
I might be screwed cause i'm not gona buy a tig welder.
Wish I could just buy water cooled heads for the fl350. I need two. One for mine and
one for my brothers machine. But they don't make them anymore and I don't know if water cooling just the heads will be enough cooling anyway. I thought about an Engine swap but that's more expensive than trying to make the two smoke run and it's a big job. I have been keeping tabs of all the swaps here on this site. Cutting and pastein to word pad all info. Sue me for stealing info LOL.
PostPosted: Mon Oct 28, 2013 2:58 am
I wish emmanuel farrugia would post some stuff on his swap if he is finished it.
I think he was the one that was doing the polaris ho500 swap.
Really wanted to see some performance results on that swap actually.
PostPosted: Mon Oct 28, 2013 3:00 am
who did you contact about the water-cooled heads?
PostPosted: Mon Oct 28, 2013 3:26 am
I was looking at the aftersucks motorsports site for them.
PostPosted: Mon Oct 28, 2013 3:55 am
so hes not making them any more?
try hillside honda
http://www.hillside-honda.com
shoot them an email
there was a rands head on ebay for a while now im guessing it finally sold last month some time ???
PostPosted: Mon Oct 28, 2013 10:07 am
Speedchaser needs to run a batch of basic heads for the FL350 a smart design could also use the blank for a FL250 liquid cooled head just a different bolt pattern and dome.
Basic meaning something like this
http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=506
Or something like the Rand heads
I would not give up just yet on welding do some reading here?
https://www.google.com/search?q=fl350+w ... 3Aofficial
PostPosted: Mon Oct 28, 2013 10:11 am
I need to finish this cylinder so someone can try it http://www.pilotodyssey.com/PO/viewtopic.php?f=5&t=10687
PostPosted: Mon Oct 28, 2013 4:26 pm
Hey hoser you clearly have welded successfully a fl350 cylinder before.
1) Did you use a tig welder or a mig?
2) What did you use to clean the aluminum?
There was a reference made about sand blasting.
PostPosted: Mon Oct 28, 2013 6:29 pm
Used a Miller syncrowave 200 tig welder, sand blasted to clean the aluminum then wiped down with acetone some areas were brushed with a stainless brush and or a scotch brite pad.
PostPosted: Mon Oct 28, 2013 10:04 pm
Pics?
PostPosted: Tue Oct 29, 2013 12:44 am
mozzy wrote:
Pics?
If I get this to work with my new miller spool gun I will post pics.
But I am in no mood to buy a tig welder right now.
I have a milling machine and lathe as well so maybe I should try to build a head
from scratch. I don't think it would be that tough but getting the correct design angles
would be, but I could make something reasonably close. Just don't know how good the
performance would be because there is some real math involved in designing a head.
Looking at the pics Hoser posted of the water cooled head I think I could do, just didn't
want to go through all the effort if I could have bought two after market units.
PostPosted: Tue Oct 29, 2013 1:02 am
mozzy wrote:
Pics?
did you try to contact hillside Honda?
the head they make is that nice red one of the photos from HoSer's link
Billet aluminum head they look very sick
or rotax them :-)
PostPosted: Tue Oct 29, 2013 1:08 am
I also have a billet Hillside Honda Head....actually s/n #1
PostPosted: Tue Oct 29, 2013 2:31 am
mozzy wrote:
Pics?
or rotax them :-)
Think I might try that hillside Honda suggestion.
Just came in from the shop and was trying to weld on the head fins again. Just got frustrated.
Must be a lot of magnesium in these heads. What a pain.
Will try to search this site for the number. I know I have seen it here somewhere.
In your opinion is a water cooled head enough or should the cylinder be water cooled as
well? Is just a water cooled head a waste of $$$?
PostPosted: Tue Oct 29, 2013 2:35 am
A water cooled head is not a waste of money but if you want total protection, water cool the sleeve too.
PostPosted: Tue Oct 29, 2013 3:05 am
ill agree with rand on this one
the last price i heard from hill side honda was $375 bare aluminum($60 more for anodizing)+ shipping and that was a year ago on the 14 of november
mine had just a water cooled head and it was great never had a problem
only reason i say a go rotax is power :-)
just from me testing mine to see how it rides it has way more balls to them than the stock Engine and my jetting is super fat on the low end(im talking clearing its throat before the power kicks in) cant wait to see it run when its jetted right
i say make one a water-cooled stock Engine and make the other one a rotax 440 :-)
i have hillside hondas BRD racing email ill pm you the email addy
PostPosted: Tue Oct 29, 2013 4:21 am
the last price i heard from hill side honda was $375 + shipping and that was a year ago on the 14 of november
Thanks for everyone's input.
PostPosted: Tue Oct 29, 2013 9:06 pm
I sent hillside an email and here is their reply:
Hello,
Yes I am the manufacturer of the Hillside Honda Water-cooled heads for the FL350. I am out of stock at the moment with no plans for more; unless I can get an order of 4+ going. The Cost/Time of building them is pretty high with not much room for profit. Seeing as how another company makes one for around $350 (a much less detail oriented model), my CNC Billet Head has to be around $400-$425 to make any profit. I love the project as we have one of the greatest historical ties to the Odyssey world, and am glad to get an order going if you can generate some interest.
Thanks for your time and feel free to ask any more questions!
Trevor
Hillside Honda
Brown's R&D
Here he mentions another company makes one. Does anyone know who??
PostPosted: Tue Oct 29, 2013 9:50 pm
I'm guessing chucklenuts at aftershot motorspurts motorsports
that really sucks at his price went up that much
and that would be a different model than the one Randman has
now I'm wishing I would have pulled both liquid cooled heads from my Odysseys before I sold them
at least I pulled all the other goodies :-)
PostPosted: Wed Oct 30, 2013 12:39 am
No its not chucklenuts!
Its Rand Manufacturing out of Bakersfield Ca. And no I'm not the Rand of Rand Manufacturing.
Here is the ebay posting for the last one they sold. Email them and see if they can make one for you! You see them quite often on ebay.
http://www.ebay.com/itm/HONDA-ODYSSEY-F ... 83?vxp=mtr
PostPosted: Wed Oct 30, 2013 12:47 am
http://www.ebay.com/itm/HONDA-ODYSSEY-F ... 83?vxp=mtr" ."..
That seller is not the manufacturer of that head i don't believe. He is a guy that just had a large horde of pilot and odyssey parts.
