It is currently Thu May 15, 2025 3:05 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Thu Nov 21, 2013 11:39 am
kbrott wrote:
Are you happy with them? They are about 45 minutes away from me, I may try to stop by there.
Happy as heck with mine, is Yoda still making his front suspension kits?
If not you might consider going with Dave-Co's setup http://www.pilotodyssey.com/PO/viewtopic.php?f=5&t=10621
More of his stuff here http://www.pilotodyssey.com/PO/viewforum.php?f=60
PostPosted: Thu Nov 21, 2013 12:47 pm
That kit needs some refinement. It also does not take the abuse of hard trail riding. The extra travel is worth it, but don't expect it to be a perfectly engineered kit that will make it through years of east coast trail riding.
PostPosted: Thu Nov 21, 2013 3:01 pm
Someone been having a problem with his kit, what kinds of problems you seening? I been beating the basically same kit since 2003 the Yoda kit is a direct copy of the kit Redriders buddy made me http://www.pilotodyssey.com/LTfront1.htm I have not seen any problems I can complain about the arms appear to be stronger than OEM I still have my first kit seen in the link I provided it would have been installed on the wifes Pilot by now but I cant see spending 400 bux in shocks for something that currently never is used :-)
PostPosted: Thu Nov 21, 2013 3:49 pm
I am interested in Dave-Co's arms, but don't want to find old arms to hack the ball joint out of
I asked him if he could weld in a fitting for Stator's ball joints, but he said they do not have enough angle and needs the stock pilot or 400 joints
I can't find it off hand, but I thought the stator joints were +/- 25 (50)
It would seem any arm with a replaceable ball joint would be a much grater value, and could be fine tuned for camber
I haven't really followed up with him since
Any thoughts out there on this?
PostPosted: Thu Nov 21, 2013 8:10 pm
I thought trx450r arms used the same ball joints.you can get those for a dime a dozen on ebay
PostPosted: Thu Nov 21, 2013 8:46 pm
I have a set of pilot arms for sale. I was going to use them for the same thing but ended up going a different route for a front long travel.
PostPosted: Thu Nov 21, 2013 10:08 pm
Has anyone tried modifying 450ex arms to make them fit
