It is currently Tue May 13, 2025 6:08 pm
 Post subject: Re: Dave-co LT
PostPosted: Tue Jan 21, 2014 5:07 pm
Dave-Co wrote:
yes 2 stock axles to make 1 long axle
So let me get this straight: it takes 4 stock axles to make a pair of LT axles, and you're still limited to the angular travel of the stock u-joint? Not sure if I love that idea and its limitations, but it is what it is. I'm anxious to see some GoPro of this setup in action.
**(Edit: when I typed this post I was thinking it was an FL350. But, I was 100% wrong. Its a Pilot and Pilot axles.)**
PostPosted: Tue Jan 21, 2014 5:40 pm
pilot has CV joints. not u-joints
PostPosted: Tue Jan 21, 2014 6:17 pm
running the pilot CV joints at 30 degrees is in no way a limiting thing, the pilot cv joints hold up and have no trouble running more angle than 930 cv joints run, how you call that limitations baffles me. The pilot cv joints are excellent, mine turn free at 34 degrees, a 930 will burn the grease out and fail at 30 degrees axle angle and we push the limit with special cages and balls to 28 degrees on my race cars.. the pilot cv joints allow 17 full inches of true wheel movement, where is the limitation in that?
PostPosted: Tue Jan 21, 2014 6:47 pm
Go look under Dave-Co's world video footage is up of his set up compared to stock they have been up for 4 months
PostPosted: Wed Jan 22, 2014 9:57 am
OHHHHHH my bad, guys. I keep thinking FL350!! :shock: Sorry about that. I was just like "Whyyyyy would someone do that?", but glad I was thinking bass ackwards. :-)
Game on.
PostPosted: Wed Jan 22, 2014 11:18 pm
No sweat, I tried to explane all as best I could, the best rear end mod for a fl 350 is adding a 10 inch travel fox 2.0 shock. easy to tune the rear to handle 5 times better than they handle now.
PostPosted: Mon Feb 03, 2014 8:00 pm
here's a couple pictures of the long travel
PostPosted: Mon Feb 03, 2014 11:40 pm
10" travel shock for approx. 4" of shock stroke?
PostPosted: Tue Feb 04, 2014 2:32 am
It is what you do with that shock stroke that changes the ride considerable. Valving the shock to the travel is something works or any other can not come close t0
PostPosted: Tue Feb 04, 2014 11:30 am
Sorry Dave, did you already do a write up , or detail this?
I've got a ody that has works shocks needing attention
I'm just not sure I want to give any attention/$ to those shocks
PostPosted: Tue Feb 04, 2014 2:38 pm
just a little, i don't have a 350 to do one with but i had them in the past and it worked well
