It is currently Wed May 14, 2025 9:51 am
PostPosted: Mon Mar 24, 2014 8:56 pm
I just picked this up Friday. It has been sitting up for many years and needs some help. the fuel lines had all been removed and I have no idea where they go. the Fuel pump looks new.
PostPosted: Mon Mar 24, 2014 9:08 pm
first thing was to soak the carb. if you have never tried pinesol as carb cleaner you should. I will never use carb cleaner again.
the carb was jettet with a 140 main
45 slow
35 slide
and the needle is on the top clip.
the fuel lines were disconnected and the T-fitting had the return line blocked off. How can I tell if I have the correct float?
PostPosted: Mon Mar 24, 2014 9:09 pm
Looks nice, the 350 service manual will show the factory hose routing.
PostPosted: Mon Mar 24, 2014 9:12 pm
the fuel tank was rusty so I dropped it off at the local radiator shop to be vatted.
I did start it though. I used an old coolant bottle from a Polaris to supply some fuel.
PostPosted: Mon Mar 24, 2014 9:13 pm
is there an on line version?
found it. I see some people run clear lines where can I find them and what size?
PostPosted: Mon Mar 24, 2014 10:27 pm
Here is a pic that was sent to me to figure mine out.
PostPosted: Mon Mar 24, 2014 10:41 pm
350 fuel line diagram.
Fl350 Fuel Lines Routing
File comment: Fl350 Fuel Lines Routing
PostPosted: Tue Mar 25, 2014 9:56 am
thanks for the help. ill try to make a report on the progress once i get the tank back.
PostPosted: Tue Mar 25, 2014 10:56 am
Lemon or lime juice in a pan on the stove is the best carb parts cleaner I have ever seen, will have to try the pinesol thing you use it straight?
PostPosted: Tue Mar 25, 2014 11:21 am
i used it straight. Google pinesol carb cleaner and you will be amazed at the results. You really don't even have to take the carb apart although i do. Just look at my pics and that is onlt a 3 hour soak. Not to mention the shop smells clean!!
PostPosted: Wed Mar 26, 2014 9:05 am
Awesome! And it doesn't eat plastic parts? Love it.
PostPosted: Wed Mar 26, 2014 10:48 am
nope, and does not bother the rubber gaskets.
PostPosted: Fri Mar 28, 2014 7:24 pm
small update on this project. I managed to get 3 new fuel filters today. I ordered the FRAM G4168 from advanced auto parts as discussed in this post. :-)
viewtopic.php?f=64&t=9724
the gas tank is still at the shop so no ride yet. This was supposed to take two days and it has been five. that sucks.
I did pull the steering column to clean / lube it. the steering was extremely tight. the lower end of the shaft was corroded up. i cleaned and lubed it with synthetic boat trailer bearing grease. the steering is super easy now. :-)
the left upper J-Arm bushing is worn and letting the wheel tip in. can i replace them? a bigger problem is that I think the J-arm mount may even be slightly bent. That sucks. I guess a TRX450r suspension may be necessary.
next i need to buy a battery and replaced the pull rope.
PostPosted: Sun Mar 30, 2014 9:02 am
Glad you found the filter at advance... I may have to order a few myself. I tried to order from
Autozone and you are correct... They can't get em anymore. Thanks for the update!!
PostPosted: Sun Mar 30, 2014 10:00 am
no problem.
look what followed me home last night. a 2005 trx450r with an Engine problem. (sellers pic) it may be a suspension donor for the fl350 if it is too far gone. I think (hope) that it may just be the cam chain slapping. I'll be doing a CSI later today.
(edit) the whole bottom end is trashed. dang it!!!!!
My two car garage is getting full with a 71 bronco, 90 Polaris sportsman, 50 Polaris preditor, fl350, fl450, and now a trx450r. that does not included tools, welders, metal brake, etc.
PostPosted: Sat May 31, 2014 8:40 pm
well it is alive!!!
PostPosted: Sun Jun 01, 2014 4:37 am
You can get a pdf copy of all three oddy models here at this site: http://www.atlanticpaints.com/Manuals/O ... anuals.htm
It's free.
PostPosted: Sun Jun 01, 2014 7:30 am
no problem.
Is the Engine worth rebuilding or is it like the the dirt bikes 3-4k bux to repair?
PostPosted: Sun Jun 01, 2014 1:59 pm
it will be around $750 in parts to rebuild.
Registered users: Google [Bot], redskinman, socalgii, wyeeoddy
