It is currently Sat May 17, 2025 10:33 pm
PostPosted: Tue Apr 01, 2014 7:03 pm
http://sandiego.craigslist.org/nsd/snw/4511666072.html
Cheers,
Tadrad
PostPosted: Tue Apr 01, 2014 8:19 pm
Beautiful Pilot, good luck with the sale.
PostPosted: Tue Apr 01, 2014 9:07 pm
Hey Tadrad can I ask a few questions? For the rear shocks, what spring rates did you end up using for tenders and mains, also where did you set your crossover and how far down did you set the preload. Im trying to dial in my ATVR Axis LT, I changed from 125 over 150 to 100 over 125, havnt had a chance to play with the crossover or preload just yet, just looking for suggestions. Thanks and good luck with your sale.
PostPosted: Wed Apr 02, 2014 3:57 pm
I am running 100s over 125s. I'd have to have a look crossover setting? I move the preload around depending on the terrain? Surface of the moon being so different to Dunes!
PostPosted: Wed Apr 02, 2014 4:23 pm
Crossover is the point when you go from ride spring to main springs. Basicly the. Adjustment when the bottom spring is set to.
PostPosted: Wed Apr 02, 2014 5:37 pm
Great looking pilot, good luck with the sale!
PostPosted: Wed Apr 02, 2014 6:34 pm
very nice!!!
PostPosted: Wed Apr 02, 2014 10:23 pm
Thak you sir. Ill make some adjustments to see what works for the dunes
Registered users: Bing [Bot], Google [Bot], liduno, MSN [Bot], Q
