Pulled the
Engine out of the Wolfskill Pilot so it can be inspected/hoserized.
I had checked the compression here at home and found it at 170 psi at 500' elevation I will cc the head when I get a chance to see what it actually is, the Engine that goes into my Pilot will have a
Speedchaser cool head regardless
I have seen this red thread locker before many times come across my bench, I assume its ATV Racing that uses it since I have seen it so many times, it must be a slow drying thread locker since a lot of times it has that star look where it was flung off when the Engine was started.
I don't see the normal oil behind the star (recoil thing) you usualy find in a Pilot Engine that means the seal is not leaking, someone was inside this Engine not long ago.
No real drama on the outside of the Engine other than the mismatched bolt in the side cover, right length just the smaller head, not a big deal I have spares.
Nothing abnormal found inside the case, nice and clean inside.
That red thread locker must be the type you might need to heat to get it to release I had a hard time getting the big nut off with the impact.
