It is currently Fri May 16, 2025 5:50 am
PostPosted: Sun May 02, 2010 8:33 pm
spec for fl350 from hotrod cat
its the cr250r 1984 to 2001
Note the thrust washers are to be 1.2mm = 0.047244094488188976377952755905512
Note the pin is to be 59.5 mm long
so if you get the 8160 kit you will get a shorter pin that may not work as well
the thrust washer that are 1.25mm May work = 0.049212598425196850393700787401575 maybe tight
.85 mm = 0.033464566929133858267716535433071 maybe to lose
FL350 Honda Odyssey crankshaft rebuild repair rod replacement.
File comment: rod kit 8103
PostPosted: Sun May 02, 2010 8:59 pm
now Pro x spec out the cr250r for a part # of 03.1315
this one has the 59.6mm long pin and the 1.2 mm thrust washers
PostPosted: Mon May 03, 2010 9:31 am
Note nobody make a rod kit for the fl350
as i seen with the right parts yet
this is what Honda used
Rod center to center = 125.3 mm
big end pin length 62.56 mm not available any more
stock Honda thrust washers 1.2mm Thick
so you are go to get thicker thrust washer or a shorter pin
I think THE PRO=X ROD kit for the cr25r 84-01 my come with the longer pin 59.6 mm and the 1.2 mm thick thrust washers
call Rocky Mountain http://rockymountainatv.com and the clarified it that it come with the longer pin and the 1.2mm washers
So as of right now if you see a rod kit for a fl350 watch what you are getting as noted above
speed
 Post subject: Re:
PostPosted: Sun May 25, 2014 7:50 am
call Rocky Mountain http://rockymountainatv.com http://rockymountainatv.com and the clarified it that it come with the longer pin and the 1.2mm washers
speed
Thanks for the info, so what prox part number do we need to use?
