It is currently Thu May 15, 2025 4:33 pm
Post new topic Reply to topic  [ 226 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 10  Next
PostPosted: Tue Jun 17, 2014 7:50 pm
Not yet I spent this past weekend prepping my other 350 and my banshee for the dunes this weekend. Stripped all the suspension off the odyssey. Cleaned and painted it. No more gold! It looks soo much better than it did. I haven't had a trip to the sand in almost 4 years. So I'm due for a good escape.
PostPosted: Tue Jun 17, 2014 9:01 pm
The frame could use fresh paint. But It cleaned up nicely. This one I've kinda designated to my girlfriend. I spend a lot of time on mine. I figured I'd clean hers up a bit. I did some cleaning and painting on my banshee as well.
PostPosted: Wed Jun 18, 2014 8:53 am
jknarfal wrote:
This is the oil reservoir I was thinking of using. It may be perfect to use for the shaft oiler with pre mix. These are cheap too. Around $30 New on eBay. This one is missing the sight glass. But they come with it new. So you would be able to keep a eye on the level and cleanliness of the oil.
use clear hose for the lines. All i have is a long line with a K&N style PVC vent on the end of it. that way i can see the oil level each time i get in.
PostPosted: Wed Jun 18, 2014 10:56 am
Yes I like that idea the reservoir I bought has a sight glass on the side as well. It said it's 750ml capacity. So hopefully having more will help keep that oil cooler. It should be arriving today I'll post a pic this evening.
PostPosted: Wed Jun 18, 2014 11:53 pm
This is the canister I was shipped but I ordered a polished aluminum one. So it'll be going back. But other than the finish its the same. Looks like the hose nipples are the right size for the oil lines on the rotax
PostPosted: Wed Jun 18, 2014 11:59 pm
Stupid eBay
PostPosted: Sat Jun 28, 2014 8:08 pm
update?
PostPosted: Mon Oct 06, 2014 12:38 am
Finally got back on my project here. It's been a bit. But I started building some steering today. I machined up these for the idler arms. I think they'll work well.
PostPosted: Mon Oct 06, 2014 1:01 am
let me guess
3/8 ID and 7/8 OD bearings?
PostPosted: Mon Oct 06, 2014 1:04 am
They're metric.
PostPosted: Mon Oct 06, 2014 1:11 am
There 10mm id and I believe 19mm od. I made the sleeve for the center so when its all tightened up with the through bolt it won't bind or put a side load on the bearings.
jknarfal wrote:
They're metric.
aw
i went with standard since i have a crap ton of grade 8 bolts in std
PostPosted: Mon Oct 06, 2014 1:12 am
i did the same
but im no longer a odyssey owner as of today :shock:
PostPosted: Mon Oct 06, 2014 1:28 am
Idler arm
PostPosted: Mon Oct 06, 2014 1:30 am
Really you sold it huh? Was that the black one on craigslist that's been on there a while?
PostPosted: Mon Oct 06, 2014 1:34 am
Yup that one
there's a lot of people low balling me all the time
or wanting to trade for crap
some guy that ended up getting his odyssey stolen bought it from me
PostPosted: Mon Oct 06, 2014 1:37 am
You have a pilot as well right?
PostPosted: Mon Oct 06, 2014 1:43 am
Yup
viewtopic.php?f=61&t=14809
PostPosted: Thu Oct 09, 2014 11:57 pm
Did some more work on the idler arms today.
PostPosted: Sun Oct 12, 2014 10:42 pm
Worked a bit more on it today. Built a tie rod. It moves smoothly and no signs of bump steer. But I'm not certain I have enough travel. The knuckle turns as sharp as a stock 350. But the controls do not turn as far. So I would have faster steering. I'm not sure that's what I want. Anyone encounter this?
PostPosted: Wed Dec 17, 2014 9:04 am
I just purchased the Farr 583 kit for my Pilot and wanted to know if you guys rewired the machine or tied into existing wire harness. Any help would be appreciated.
PostPosted: Wed Dec 17, 2014 11:03 am
Honestly I haven't got that far yet. Wiring is a big to do on my list. I still need to wire the Engine, stop and tail lights, reverse light, trail tech vapor, and my heated hand grips. Please post any info you find. What Engine do you have for the swap?
PostPosted: Sat Dec 20, 2014 9:29 pm
Finally got a chance to do some more on my exhaust. This is the stock ski-doo pipe and I did not add nor remove any material. So it should perform properly.
PostPosted: Sat Dec 20, 2014 10:27 pm
You should buy a pilot steering wheel so you will have all the the stuff wired into the wheel
Then you have brake lights and way better brakes
I had a pilot wheel on my odyssey. And it make the brakes so much better
Then you could add power steering if you would like
PostPosted: Sat Dec 20, 2014 10:46 pm
that's my next purchase I think. As soon as funding becomes available Id like to do that. Did you have the 350 with the longtravel rear and the aftermarket gear box?
Registered users: Baidu [Spider], Bing [Bot], c5racer, Google [Bot], liduno, Rppjr
