It is currently Sat May 17, 2025 8:43 pm
 Post subject: 1990 pilot restoration
PostPosted: Thu Jun 19, 2014 10:15 pm
Decided to tear apart my pilot and redo it since it was overdue
Here is my project pics
PostPosted: Thu Jun 19, 2014 10:17 pm
Tearing it apart
PostPosted: Thu Jun 19, 2014 10:22 pm
Frame had a bad diamond to it. Guy before me nap must have hit it straight into the lower right corner hard enough to bring the whole right side frame back ..I had to straighten it out on a frame machine at work. A little improvising and it worked well
PostPosted: Thu Jun 19, 2014 10:24 pm
You can see here the front section out of square
PostPosted: Thu Jun 19, 2014 10:25 pm
There was no kind or any previous repairs so the frame was a really good piece except for that . The oem hondaline bumper was pretty beat when I got it,,,here's a pic from when I first got it from my (now) friend ken
PostPosted: Thu Jun 19, 2014 10:28 pm
Off to my powdercoater for a fresh coat,..the powdercoater by me does awesome work... Better than factory !!
Home now ready for assembly
PostPosted: Thu Jun 19, 2014 10:32 pm
Rear end
PostPosted: Thu Jun 19, 2014 10:34 pm
Putting parts onto frame
Painted or replaced most parts
Lots were reused
Painted a arms,,a Auto paint and clear
Powdercoated springs
PostPosted: Thu Jun 19, 2014 10:37 pm
Was able to come across some mint parts as I go
Nice hondaline front bumper and oem hondaline skid plate in greT shape
This ones getting all the hondaline tube parts
Front rear and nerf bars
Had a mint set of nerfs and rear that came with my 89 pilot that i pulled off for this one
PostPosted: Thu Jun 19, 2014 10:40 pm
Going with the aluminum rear trailing arms....they look purdy! :)
Really good design actually ...good quality
I adjusted them to the length of the oem ones and bolted in with all new oem hardware!
PostPosted: Thu Jun 19, 2014 10:45 pm
The Engine was sent to hoser to be rebuilt
Great job . Here are some progress pics!
It's sitting on the bench waiting to be dropped in
I wanna get it as a roller first
Here Is original thread
viewtopic.php?f=1&t=13143
PostPosted: Fri Jun 20, 2014 12:22 am
Damn that's looking good
PostPosted: Fri Jun 20, 2014 9:03 am
Looking real good are you almost done?
PostPosted: Fri Jun 20, 2014 9:35 am
Sweet.
Regarding the aluminum rods? Have they been proven? To me, the hex section looks like a huge stress riser. Probably depends on how you ride.
PostPosted: Fri Jun 20, 2014 10:12 am
Hoser- no it's at the latest stage you see in pics....taking my time,,,putting my 89 back together to ride it ( non resto)
I haven't tested the arms but they are solid throughout except where they are threaded... I wiping be hammering this one so they should hold up lol
PostPosted: Fri Jun 20, 2014 10:35 am
Looks nice - great work. I like the Blue brake levers. Are you rebuilding the drive train? What are you doing for the plastics? Do you have the small decals to put on the frame? Are those the stock reservoirs on the rear shocks? What is the red on them?
PostPosted: Tue Jun 24, 2014 9:15 pm
Thanks for the compliment
The red is just red carbon fiber vinyl I wrapped them in since they were a little aged
I threw the blue levers on there to get a little more blue on the machine without getting crazy
The drivetrain is going to consist of a rebuilt Engine from hoser and the tranny I'm going to open up and put new seals and gasket
that is once I get the stubs out!!
I'm having trouble getting them out
I went as far as drilling through one side and trying to beat it out with a punch and hammer,,nothing..been soaking in on blaster for months lol
I don't know what to tow..I made a decent puller as well and nothing...any suggestions.??
Plastics I have a clean set I was running on there before I tore it down...I bought the 4 fenders new and the others were decent..I also bought all the warning labels for the frame
I'm still trying to hunt down someone to print me the year decal for the back of the frame
I've seen a lot to atc ones on eBay and even fl250 ones
PostPosted: Tue Jun 24, 2014 11:20 pm
Also want to add that I used CERAKOTE for the first time
Wow does this stuff work awesome
It's a ceramic paint that many use for guns etc...it's a high temperature coating that comes in air dry form or bake form
I bought a pint of the air dry,,,pretty pricey but well worth it -----60$
Parts need to be sandblasted clean,,,then a few light consistent coats and your good,,need to have a mini spray gun to apply
It looks like factory oem satin black
Btw I have half the pint left after doing 2 expansion chambers and silencers
Have one of the pipes set up on my 89""" no discoloration or burn off and I've ran it pretty hard for a couple hours
PostPosted: Wed Jun 25, 2014 7:52 am
Great Job.. Looks like a new one to me. Thanks Billy
PostPosted: Wed Jun 25, 2014 10:01 am
Yea I didn't know how it would hold up..I've used other high temp paints etc in the past,,not really any good
This is comparable to JET HOT or similar...very happy
Good if your pipe is looking a little ratty and want to keep it from rotting away
PostPosted: Wed Apr 06, 2016 10:58 pm
Hey guys..its been a while I finally got around to finishing th 1990 project!! Stayed pretty close to original as possible ..I still have a couple pieces to put back on but it's pretty much there
Registered users: Bing [Bot], c5racer, eseymour72, Google [Bot], liduno, MSN [Bot], Q
