RobDek wrote:
Find me a reference for NOS
Engine pricing and I'll be happy to adjust accordingly. Gotta start somewhere, right?
Personally I think anybody / you can ask any price you want for parts, machines, services long as your giving all the details you know aobut the parts, machines, services.
Do you know that Engine has the pre recall head on it?
Do you know their is a great possibility that is a re recall Engine and that its a used Engine with a unknown amount of hours on it.
How were these engines stored since it was removed open like in your pictures?
IMO your asking way too much for a bunch of unknowns, you can help yourself justify the price by pulling off the head and putting the piston at bottom dead center take detailed clear pictures of the cylinder walls so the condition can be seen, then put the piston at top dead center and take pictures of the rod and crankshaft so perspective buyers can see if their is any dirt and rust inside.
If I was selling this Engine I would at the very least pull the whole top end off so I could verify and validate the engines internals, take plenty of detailed pictures, you can tell by the pictures if their is any wear or scuffing on the piston and cylinder walls, I would also take pictures of the crankshaft rotating it so the pictures verify their is no rust or dirt on it anyplace.
If the Engine is NEW or near new low hour I would replace the mag side crankshaft seal, I would also ensure the exhaust bridge was properly relieved and drill the lube/cooling holes in the piston and reinstall the top end, I would bolt the head on snug tight without the new head gasket installed so the perspective new owner could change the head to the updated head.
After doing all this and the Engine proved to be clean, not rusted, low hour or a new take out Engine I would not hesitate to ask 800 bux for it.
IMO anybody that paid more than 300 bux for the Engine with all the unknowns and just going by your pictures and description would be a idiot, WHY well its simple Honda replaced, repaired and updated EVERY FL350 they sold this cost them THOUSANDS of dollars they only did it for a very good reason because their was some serious problems with the engineering and design of the original FL350s including the engines.
Installing and running this Engine is a huge gamble it might last 5 minutes or 5 years you cant see if their is dirt and rust in and on the crank and rod bearings without taking the top end off.
Their are other unkowns about the pre recall FL350 Honda Odyssey engines that's never been clarified or verified, I have heard many stories about these engines I was told that ALL the 350s were recalled and ALL the engines were replaced even if they were running perfect and the owner had no problems with them and ALL the recalled Engine were destroyed, also heard most the recalled engines were given away to trade schools for training purposes and most them after mane years made it back on the market for use or for sale.
I have also been told if the Engine was blown up they replaced the whole Engine with new, if they were still running they just changed the top end and kept the original bottom end installed.
The sources that told me ALL the engines were replaced said Honda changed the timing on the updated engines by cutting the flywheel key in a new location on the crankshaft so using the old pre recall crank would give the owner the old timing curve that was part of the Engine blowing up so easily so the poofkabbom issue would last the life of the pre recall Engine, I have never been able to verify this you would need a pre recall crankshaft and a post recall crankshaft side by side to verify this OR have two assembled engines verified pre and post recall engines side by side so you could use a degree wheel and verify the flywheel key is in the same location.
To complicate things even more others has concluded Honda just changed the flywheels and that is how they changed the timing not by the key in the crankshaft, they also apparently changed the
CDI (Capacitor Discharge Ignition) box giving the timing curve and rev limiter an adjustment.
About 15 years ago I had a phone number at Honda that I called and the lady read to me what Honda did during the recalls this was suppose to be the official word what they did, she would not mail me or email me the list only read it over the phone, ALL these details of the phone call was lost when Kiowa the dumbfuck confiscated my old Pilot Odyssey website, maybe Lee knows how to contact them to hear the recall details again?
Again IMO ask 10 zillion dollars for your stuff but if you list it where people who know about these engines or stuff expect them to come forward and notify others, if you want to dump your unkown stuff on some unsuspecting ignorant buyer take it to evilbay and play your capitalism games and go to sleep telling yourself "its not my fault the buyer did not do the research" excuse
