It is currently Sat May 17, 2025 11:42 am
 Post subject: aluminum wheels
PostPosted: Sun Feb 23, 2014 5:12 pm
Hello friends, I have a question, that alloy wheels can be used in the pilot??
 Post subject: Re: aluminum wheels
PostPosted: Sun Feb 23, 2014 5:36 pm
If you are going to use aluminum wheels, get the douglas red label (.190) or ITP wheels (also .190) the douglas blue label and black labels are thinner material and bend easier. But beware, the offset/back spacing on the front wheels is different than stock and will widen your front end, making the steering perform differently.
PostPosted: Sat Aug 02, 2014 9:00 am
and what would be the ideal model to not alter the offset, because I'm going to put the reform discs in the front???????????
PostPosted: Sat Aug 02, 2014 11:18 am
If you have the extra money, I would suggest getting the beadlocks too
PostPosted: Sat Aug 02, 2014 11:19 am
There are no aluminum wheels with the correct offset that will fit the pilots bolt pattern
PostPosted: Sat Aug 02, 2014 2:14 pm
so if I put aluminum wheels, which is what most resembles what you have to go??
the money is not a problem
PostPosted: Sat Aug 02, 2014 3:21 pm
4+1 offset is the closest you will find. Omf made a set of beadlocks for a few guys. May be able to call and order
http://www.pilotodyssey.com/PO/viewtopi ... &hilit=OMF
