It is currently Sat May 17, 2025 12:18 pm
 Post subject: Looking for Gas Cap
PostPosted: Tue Aug 12, 2014 9:48 am
Looking for Gas Cap for 1990 Pilot FL400
 Post subject: Re: Looking for Gas Cap
PostPosted: Tue Aug 12, 2014 2:11 pm
Is yours missing or did you loose the key?
PostPosted: Tue Aug 12, 2014 2:20 pm
Spare key currently stuck in cap looking in case we cannot get it out. So far WD40 no work
PostPosted: Tue Aug 12, 2014 2:25 pm
The key will only come out if the cap if latched in the lock position, is it on the tank and will not come off.
PostPosted: Tue Aug 12, 2014 2:27 pm
WD-40 does not work good on rusted parts, get some PB-Blaster.
PostPosted: Tue Aug 12, 2014 2:53 pm
Cap attached not locked on can put cap on tank just cant get it to lock and release
Will play some more, we may have forgotten all the specifics
PostPosted: Tue Aug 12, 2014 2:59 pm
i believe you have to push down on the cap to get it to lock. i don't think the key will spin otherwise
PostPosted: Tue Aug 12, 2014 3:00 pm
Are you pushing down on the cap to lock it in place?
PostPosted: Tue Aug 12, 2014 3:35 pm
yes you need to push down with the dust cap out of the way, if it doesn't snap over on it's own you may need 2 people, one to push down one to turn the key ccw, I would use some of the graphite spray available, goes on liquid then drys and only leaves the graphite behind.
PostPosted: Tue Aug 12, 2014 8:40 pm
lol, i just got a pilot and did the same thing didnt know how to lock it and get the key out. hope you figure it out.
PostPosted: Wed Aug 13, 2014 10:58 am
Thank You all so much that's all it took was someone to retrain the brain. I got to the cap just as my husband was about to do something stupid with it. Key is out no problem cap still intact like new. Phew!!
I appreciate the help
